Old 06-18-2009   #1
All my dsm,evo,mirage parts in 1 list FS/FT
JDM data plates
model: E-CD5A SNDF
chassis no. CD5A-0101523
engine: 4G93 ext: H84G
trans axle: W5M33 3545
color, int opt H84 29J 000
take 25.00 for them both
set of reflectors
here is a pic of them the outer tails and the center for the jdm plate does not come with them
40.00
set of evo I front recaro's they were in my car till I put in the evo III recaro's they are in the same shape I bought them in. the drivers set (right) has a hole worn into the sude easy fix I just never did it. the left seat is mint. they dont come with brackets I reused them for the evo 3 seats. 300.00 for the set of them.
oem p.p. 10.00
Exedy p.p. like a 2600 30.00
msd tach adaptor 35.00
auto meter 5" tach and shift light 100.00
auto meter red warring light new 30.00
evo III engine bay harness 75.00
evo III engine harness 125.00
evo III rs dash and body harness 100.00
act awd 6bolt flywheel 150.00
evo 9 rear wheel bearings 25.00 each
evo 9 rear knuckles 25.00 each
spyder parts and 2g/7bolt parts all spyder parts have 38k on them
tan leather rear upper seat 50.00
tan rear plastic panels 25.00 ea
tan door stills 10 ea
tan kick panels 5 ea
trunk lid with gas shocks purple 75.00
tan visors home link 10.00 set (could use a recover)
power steering lines 15.00
power steering cooler 15.00
clear front bumper lights 25.00
water pipe 15.00
oil filter housing no cooler on it 10.00
oil filter housing 20.00
rear block plate for timming cover 5.00
x2 power steering block brackets 10.00 ea
oil pick up 10.00
water pump to alt pully 10.00
alt heat sheild off the evo III 5.00
fuel filter and fuel line to rail 5.00
smic 20.00
black radio bez 15.00
heater core 20.00
fuel rail 20.00
x2 spyder top motors 50.00 ea
clock spring for the air bag and horn 5.00
air bag ecu 25.00
heat/a.c. controls 5.00
oil filter housing compleat 30.00
stock amp 15.00
eclipse tails outers 40.00
smic 30.00
x2 cams sets 20.00 set
fuel rail 20.00
x2 aculmator set ups 30.00 each
x2 crank sensors 10.00 each
1g parts and 6 bolt parts
intake mani bracket 5.00
clutch master 5.00
turbo water pipe 90 30.00
turbo water neck lower 10.00
n/a water neck lower 10.00
x2 water neck upper 10.00 ea
black w/red strip plug cover 5.00
front awd block mount lower 10.00
x2 rear awd block mount lower 10.00
x2 block timming belt filler panel 10.00 ea
x2 front upper block mount for power steering 10.00 ea
x5 upper block mount 10.00 ea
1ga back up and lic plate wiring and lights 5.00
90 awd shifter bracket for the tranny 10.00 ea
oil pick up 5.00
power steering bracket 5.00
clutch line rubber to slave 5.00
x2 water pump to alt pully 10.00 ea
x2 water pump to power steering pully 5.00 ea
x2 engine lift bracket for ext mani 5.00 ea
engine lift bracket for head to intake mani 5.00
power steering heat shield 5.00
x3 hydro tensioner 15.00 ea
horn 5.00
x5 tension arms 10.00 ea
x3 tension pully 5.00 ea
x3 idler pully 5.00 ea
x2 balance shaft pully 5.00 ea
oil pump gear for t.belt 15.00
x3 b.s. belt gear small ones 5.00 ea
x2 b.s. gear on the crank 5.00 ea
x3 main crank gear for t.belt 20.00 ea
x3 alt arms 5.00 ea
crank spacer plate for inbetween the crank gears 5.00
awd coolant over flow tank 5.00
cup holder 15.00
pwer reg drivers side 10.00
o2 housing 5.00
2din radio bez 5.00
1gb oem side lights 5.00 set
rear washer bottle no motor 5.00
green drivers door handle 10.00
white drivers door handle 10.00
x2 sets of red door handles 20.00 set
dip stick tube 10.00
battery tie down 5.00
90 fuel rail 20.00
wing never seen one like it it is urathane 40.00
tail lights 30.00
1 piston front brakes 30.00 set
moog tie rod ends 20.00 set
black and grey rear seat 20.00
black and grey front seats (will only trade for grey front seats)
power door panels 20.00 each
red gas door 10.00
red door handles 10.00 each
red power mirriors 10.00 each
black power mirriors 10.00 each
a-pillers 5.00 each
b-pillers 5.00 each
rear speaker panles 5.00 each
all trunk panels 5.00 each
good hatch struts 30.00 set
grey hatch cover not broken at all 40.00
5 speed tranny 4g63 n/t 75.00 (does not grind)
fly wheel 6bolt n/t 40.00
clutch 6bolt n/t 30.00
brake master 20.00
h4 headlight kit 50.00 (new bright phillips bulbs)
corner lights 5.00 each
turn sigle lights 10.00 each
center grill 10.00
injectors 4g63 n/t 40.00
x2 ign lock and keys 20.00 ea
door locks and trunk lock with keys 20.00 set
almost new hatch seal from mitsu 20.00
trunk and gas door cables and handles 10.00
red 1gb pass fender 20.00 needs some work not rusty
maroon 1gb pass fender 30.00
red 1gb drivers fender 30.00
1g intake manifold stock 10.00 have a few
4bolt rear end,axels,cups 225.00
also have other ramdom parts,bolts,ect just ask.
will also take trades on parts and multi parts that I have.
