Old 06-23-2009   #1
Considering stroker, looking for feedback
For the past month or so, I've been considering pulling the block this winter and going with a stroker setup.
First I'll try to explain my reasoning behind this. What I like is the fact that I will spool the turbo quicker. How much quicker I'm not sure, but quicker spool is good in my eyes as this car is 99% street driven. So the powerband starting sooner is a plus in that aspect. Also, I'm only currently revving to 8k. I usually only rev 2nd to 7500 because any higher and the tranny just doesn't like to shift as well. So I'm already not revving over 8k, and don't really plan on it because the tranny just doesn't like it much higher than that, and from what I gather a stroker setup should be able to hold 7500-8k fairly well still. So I'll be able to rev to around the same RPM, yet pickup some RPM on the bottom end due to quicker spool.
So that's why I'm considering doing this.
I've been reading up more about this, and it looks like there's quite a few cranks out there right now, from various shops/companies. I'm trying to keep it simple and cost effective, so I'm leaning towards just slapping a standard 2.4 G4CS crank into my current 2.0 block. I'm not interested in putting a 2.4 block in the car. My current block is bored 20 over. I'd want the block re-bored more due to 1 cylinder wall not being 'perfect'. So I'm looking at pistons 30 - 40 over. Right now leaning towards the Mahle's as they are what I run now and I've been happy with them. I plan to continue using my current Eagle rods.
So that is what I'm considering at the moment. What I'd like to hear is others opinions on advantages/disadvantages of going with a stroker on my current setup. Couple things are that I plan to keep the 272 cams. I may benefit from larger cams, but I need to take this one step at a time. So I'll still be on HKS 272's, a JMF Race SMIM, a stock 1GNT TB, 2.5" IC piping... I want to keep all that the same. Now with a stroker I'll be flowing a bit more air, so my concern is that I'll be choking it since I'm still running 2.5 piping and a 60mm TB. The cams could be larger too, but I only have Crower valvetrain components, so I don't want to start jumping into FP's 3,3x stroker cams when my valvetrain might not be suited for those. So I plan to keep the 272's for awhile. Plus I like the car to idle somewhat controllably, and these allow the car to still idle decently. I still have stock size valves. I guess I just want to make sure that if I go 2.3, I'm not going to see a loss in power because I find out that I'm choking it out. Maybe all my stuff is working great on a 2.0, but if I go stroker, I find out the rest of my setup just doesn't support the extra flow.
So, please if anyone has some good insight, please share as I'm already looking to start acquiring the new parts I'll need to build the stroker this winter if I decide to do so.
Thanks in advance, sorry for the long read
