Old 06-29-2009   #1
WTB: 1G Driver's Side Motor Mount
I need the driver's side motor mount for a 1G DSM. The rubber crap is destroyed on the one for my wife's Talon.
Old 06-29-2009   #2
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Re: WTB: 1G Driver's Side Motor Mount
Do you need the entire mount? I have one still on the car that I can pull off for ya.
Old 06-29-2009   #3
I don't need the part the part that directly bolts to the block and goes under the timing cover, just the easy to remove part.
Old 06-29-2009   #4
Constant_Project21
Drives: E36
Hmm, trying to remember if mine is gone or not, should still be there. I'd have to check. When do you need it by?
Old 06-29-2009   #5
ASAP, I want to drop the motor back in it. But I can drop it in with the old busted one and swap it after easy.
Old 06-29-2009   #6
Constant_Project21
Drives: E36
Ill go over and check, what do they go for? And am I going to be dropping this off at db?
Old 06-29-2009   #7
I don't know what they go for. If you want to drop it off, or I can try to meet you sometime near Roseville.
Old 06-29-2009   #8
Constant_Project21
Drives: E36
Well throw out whatever ya feel necessary. Db is a little bit of a drive, but if it can wait and meet up later then that's fine too. I live on the new Brighton-Roseville border, off old 8 and cty d. My number is 651-468-6391. Ill go and check right now if it's still there.
Thanks,
Dan.
Old 06-29-2009   #9
I have 2 of them.
1. is set up for a polly already
2. is stock staring to rip but not all the way thought. I do have a lot of polly uratine that you could use to fill it with.
Old 06-29-2009   #10
Constant_Project21
Drives: E36
Mines out and ready for ya whenever shane.
