Old 06-29-2009   #1
NTobler
Drives: 1991 Talon TSI
1991 5 speed Talon TSI AWD + free Ford Exploder
Hey guys, I'm trying to up my style a bit and go towards a 2g dsm. So FINALLY I got my car running and now I want to see what I can get for it. The car has 187,000 miles on it, but has been repaired and all the needed maintenance has now been done.
I just got done fixing
-The head was removed at some recent point and a few bolts either worked themselves loose or just weren't replaced,(thus missing all the lower intake mani bolts and had one broken exhaust stud) All of which have now been replaced
-Brand new starter
-The radiator was brown and brittle I advised to replace it, (once removed I noticed the top hose neck had cracked off, and was clamped past the break) So I put a brand new radiator in it
-the Injector seals were leaking on two injectors(replaced all injector seals)
-the knock sensor "existed" but the wire leads had been torn off, So I put a brand new knock sensor in it
-the Idle stop switch was not there, and the lead to it had broken off,(installed new spade connector)
-the coolant temp sensor wires had cracked/corroded/broken, re soldered new connectors and such,
-the transmission does not shift well into 1st gear, shifts fine in all others,
(Im about to put in an extended fork into the slave cylinder which will fix this problem)
MODS
Eco 3 16 g turbo
660 fuel injectors
255 fuel pump
2g hacked maf
SAFC 2
3" exhaust
MBC
ACT FLYWHEEL
ACT 2900 PP
AEM street disc.
GOOD
new rebuilt head and transmission-just flushed trans and replaced fluid with syncromesh.
2 new front struts
new upper strut mounts.
new front lower ball joints
new front outter tie rod ends
new u-joints
boost gauge and 3 pillar pod
new passenger side axle
new pioneer 6x9's in the back and rockford 4" up front
new Diamond Crystal Clear headlights in it
Looking for 2500 OBO NOTICE HOW I SAY BEST OFFER! IM A VERY MOTIVATED SELLER! I'M ALSO WILLING TO LOOK AT TRADES AS WELL. I WILL ADD CASH IF NECESSARY!
Shoot me a call or text any time of the day at 763-218-8078 or shoot me an email at Larsonn@augsburg.edu
Nick Larson
CLICK LINK FOR PICTURES http://www.facebook.com/Nick.theshit...8&id=598716948
NTobler is offline   Reply With Quote
