Old 07-13-2009   #1
2.4 crank pictures, opinions.
So as I said in a different thread, I am considering going with a stroker setup next year. I sourced a crank, but am a bit concerned about it. I haven't boughten it yet. The seller sent me pictures. Here's the pictures, and here is what he said. I was wondering what some of the experts would have to say about this. Also, this is a virgin crank.
Sending pics now. Make sure you look at them pretty close. It appears there is a little scoring on the center (thrust) bearing. I'm not sure if you are planning on cutting this crank or not. Let me know.
Name:	Justin G4CS Crank (1).JPG
ID:	8946   Click image for larger version
Name:	Justin G4CS Crank (2).JPG
ID:	8947   Click image for larger version
Name:	Justin G4CS Crank (3).JPG
Old 07-13-2009   #2
Re: 2.4 crank pictures, opinions.
It's really hard to tell if it will polish out or not, I sure wouldn't cut it. You really need to see it in person when it's questionable like that.
Old 07-14-2009   #3
I don't know about the 4g6x motors, but my crank is .020 under all around and it's been working perfectly for years. Just had it polished and rebalanced last winter, no extra cutting, but it's fine again. So, if all you have to do is cut it, what other problems would there be?
Old 07-14-2009   #4
some 4g cranks (usually the turbo ones) are nitrided. cutting a crank removes this nitriding, and its expensive to reapply and straighten the crank.
Old 07-14-2009   #5
jhaan_dude
jhaan_dude's Avatar
Drives: a car
of coarse the g54b cranks dont have a problem! they weight like 80lbs! it looks like it had a catch of something on the journal, either bearing or debris, but it would take some "cleaning" to smooth it out. most likely it will NOT polish out.
Old 07-14-2009   #6
my crank is forged and nitride hardened stock, so when I had it turned down it had to be renitrided. As I recall, it was less than 100 bucks. Maybe 70 or lower. Crankshaft supply did all the crank work though, so just call them, maybe ask if they can tell from the pictures what needs to happen.
Old 07-14-2009   #7
mx3twinturbo
mx3twinturbo's Avatar
Drives: StarQuests>>>>>>
Agreed,
1987 Conquest- 2.1 project started...
1986 Dodge D-50- S.C. truck 2.6 turbo swap started
1992 Mazda Mx-3- Rear mount twins in progress
1989 Suburban- Project for too Long!!!
"Just Remember, I HATE Drama"
mx3twinturbo is offline   Reply With Quote
Old 07-14-2009   #8
If the crank needs to be ground down, then I'm not interested at all. From the sounds of it, it sounds like there is a pretty general concensus that it more than likely will not polish out, and will have to be ground. So if that is the case, then I'm already not interested.
Old 07-14-2009   #9
jhaan_dude
jhaan_dude's Avatar
Drives: a car
ask iceminion he has a few of them laying around. i know he has one thats been micropolished and looks great (sold it to him!)
Old 07-14-2009   #10
Just out of curiosity, why don't you want to have a ground crank? Do they become significantly weaker or something?
Old 07-14-2009   #11
Because I have a feeling it will slightly affect bearing clearances, which I'd rather try to avoid.
Old 07-14-2009   #12
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
I didnt get that crank ready for you to check out today since I worked alot later then expected but am trying to have it ready by Thursday night for ya.
Amsoil Dealer
Old 07-15-2009   #13
Sounds good. I'm in no hurry dude.
Old 07-15-2009   #14
jhaan_dude
jhaan_dude's Avatar
Drives: a car
with a ground crank you get alot more bearing thickness. bearings arent as hard as cranks so they add squish room. in a stroker if you add a thicker bearing it allows the crank to have room to wiggle at high horsepower and rpms!
Old 07-15-2009   #15
95talonracer
Finally Tuned...
Drives: Spyder GSX
Why take the chance with a turned crank when you can get a perfect stock spec one and know it is good. If the regrind is off just ever so slightly then that was a big waste of money and time. Halon go for a stock spec, NON-ground crank. He has the time to find one since it is not anywhere near winter yet and that is when he wanted to do the 2.3 by what I understood.
Amsoil Dealer
Old 07-15-2009   #16
jhaan_dude
jhaan_dude's Avatar
Drives: a car
i know, i was trying to steer him AWAY from a ground crank!
Old 07-15-2009   #17
bob123131
Hard to tell, but i would bet you can get buy with a polish, but if your worried about it just get it ground and use race bearings, most shops wont run them with hardened cranks anywase.
Old 07-15-2009   #18
95talonracer
Finally Tuned...
Drives: Spyder GSX
I still wouldnt take a chance when pushing 550-600+ hp like it seems that he will be running.
Amsoil Dealer
