Old 07-31-2009   #1
96GST16g
livin the dream
96GST16g's Avatar
Drives: 07 zx6r and 04 Rx8
vacuum lines
i was told i can remove all my vacuum lines except the fpr and wastegate and bov is this right?
Old 07-31-2009   #2
Re: vacuum lines
You can remove all emissions systems. Be sure to get an EGR block-off plate.
Old 07-31-2009   #3
96GST16g
livin the dream
96GST16g's Avatar
Re: vacuum lines
what would happen if i didnt and do i need to block off all the ports and stuff
Old 07-31-2009   #4
Re: vacuum lines
You'll need to block off all the ports on the throttle body. You'll also have to block off the lines that go into the intake pipe after the MAS.
If you just unhook the egr from vacuum line it should stay closed I think, but you should really remove the whole EGR valve and block it off with a plate, it's cheap.
The FPR is hooked up to a solenoid for easier starting, but you can remove that and just hook it straight up to the intake mani.
Of course removing these things will give you a check engine light....
Old 07-31-2009   #5
96GST16g
livin the dream
96GST16g's Avatar
Re: vacuum lines
not so worried about that, im also thinking about doing a six bolt swap since my seven bolt jus threw a rod bearing after 100 miles on the build, what is a good budget way to go? i have a 96 GST wit a evo III
Old 08-01-2009   #6
Re: vacuum lines
2g pistons, 1g rods?
Old 08-01-2009   #7
96GST16g
livin the dream
96GST16g's Avatar
Re: vacuum lines
do u have to change anything for it?
Old 08-01-2009   #8
OMGkiwi
Drives: 91 TSI
Re: vacuum lines
you will have to machine your rods to get them to fit on 2g pistons, as there is a difference in wrist pin size.
91 TSi- Hates Me
LOL You mad bro???
OMGkiwi is offline   Reply With Quote
Old 08-01-2009   #9
96GST16g
livin the dream
96GST16g's Avatar
Re: vacuum lines
then i could keep my 7 bolt block n crank right? cuz i really dont feel like going through the shit u do wit a 6 bolt swap
Old 08-02-2009   #10
Re: vacuum lines
Magnus has a write up? I don't think it's that much?
Old 08-02-2009   #11
96GST16g
livin the dream
96GST16g's Avatar
Re: vacuum lines
alright ill take a look to see whats all gotta be done but i would like to keep my 7 bolt
Old 08-03-2009   #12
96GST16g
livin the dream
96GST16g's Avatar
Re: vacuum lines
what do i do about all the electrical connections that go to all those solinoids can i cut them off or jus tuck them away?
Old 08-03-2009   #13
Re: vacuum lines
Well if you don't have them plugged in you'll get the CEL, I'd leave the connectors there at least, not a lot of savings by cutting off the plugs.
Old 08-03-2009   #14
96GST16g
livin the dream
96GST16g's Avatar
Re: vacuum lines
so no check engine light if i leave the shit there jus disconnect the lines and plug the ports?
