Old 08-14-2009   #1
illwest
Drives: DC4
Oil Light
I have a stock 98 Gs-t and every now and then my oil light comes on. I'm a noob when it comes to DSM and I want to know what could cause it. I drive it daily and my guess is the oil pump. Any Ideas?
illwest is offline   Reply With Quote
Old 08-14-2009   #2
Re: Oil Light
Usually when the oil light comes on it's cuz of low oil pressure. I assume the engine oil is full? That light should never come on, bad things happen when it does.
Old 08-14-2009   #3
Re: Oil Light
Are you using 10W-30 oil? I've seen 5W-30 cause the light to flicker at idle during warmer temps on some DSM's.
Old 08-14-2009   #4
iceminion
iceminion's Avatar
Re: Oil Light
Same symptoms, oil pump gear came lose, drove on it for two days, then I lost all oil pressure.
Thank god i saw the oil light come on, it was at night, so it wad easy to see.
When I took the timing cover off I had half a timing belt left, very strange.
When the pully fell off to the point that was actually not turning the pump shaft anymore, the light came on.
building a 3000GT AWD Turbo.
Old 08-14-2009   #5
Re: Oil Light
Could possibly be a bad sender unit. I have a new one you can have for free if you want. Just have to pick it up. But that's probably not the problem.
How does the pressure gauge look when it flickers?
Old 08-14-2009   #6
illwest
Drives: DC4
Re: Oil Light
it dims on and off for a bit then stays on. If I rev the motor up it goes away but comes back on. I also notice just last week that I can smell burning oil after driving it.
Old 08-14-2009   #7
4seasons69
4seasons69's Avatar
Re: Oil Light
thin oil in warm weather, worn oil pump, and excessive rod bearing can all cause low oil pressure at idle. honestly my car has been doing this on and off since I bought the car 2 years ago but mine only flickers a little bit everyonce and a while then stays off and it's been fine so far
Old 08-15-2009   #8
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Re: Oil Light
Mitsubishi oil sening units are pretty prone to failure
More so on the 96-04 models
Old 08-15-2009   #9
4seasons69
4seasons69's Avatar
Re: Oil Light
that too. I think there is actually a tsb out for it
Old 08-17-2009   #10
illwest
Drives: DC4
Re: Oil Light
so could it be a bad oil sening unit?
Old 08-17-2009   #11
Re: Oil Light
You could install an after market oil pressure gauge and see what it really is doing.
Old 08-17-2009   #12
Re: Oil Light
I have had mine come on because of an old crusty wire on the sending unit, replaced wire=problem fixed
Old 08-18-2009   #13
Re: Oil Light
Are you talking about the gauge sending unit (cylinder looking with bsp threads) or the ECU one?
