Old 08-17-2009   #1
iceminion
iceminion's Avatar
Plug and Play Megasquirt for 2G.
This is fantastic news, one of the biggest drawbacks of megasquirt is that you have to create your own wiring harness or tap into the existing harness (messy)
Now, you can have all the Megasquirt goodness in an ecu that plugs right in, all for $460
Taken from the website:
OEM ECU Connector to plug right into the factory harness!
Speed Density, Alpha-N and Hybrid Alpha-N (both SD and A-N algorithms hybridized) Supported
2 Ignition Inputs (for dual wheel ignitions)
4 Spark Outputs (Up to 4 Cylinder Coil On Plug, up to 8 Cylinder Wasted Spark)
Rotary Ignition Support
Enhanced Acceleration Enrichment (EAE)
Boost Control
Knock Control
Launch Control
Flat Shift
Tachometer Output
Fully Adjustable Rev Limiter
Table Switching
4 General PurposeOutputs
4 General Purpose Inputs (2 analog, 2 digital)
Support for Flex Fuel
Optional Realtime Baro Correction
Closed Loop O2 Correction
Plenty of Proto Area, add your own customizations!
There's more than we could list here-- click this link to view the full featurelist of MS2/E.
http://www.diyautotune.com/catalog/d...kit-p-384.html
building a 3000GT AWD Turbo.
