Old 04-05-2004   #1
After installing my turbo, I took it very easy until I burned out all of the old gas in the tank. I was running 10psi (I stepped on it once to check the boost). The gas is gone and I was about ot tune but I cannot build more than 0-2 psi boost. I did a boost leak test and cannot pump more than that in my system. I am using a compressor. I cannot hear any leaks though. I am guessing that my vaccum lines are set up wrong or something. It is wierd that I could hit 10psi before though. I checked the turbo (spins freely, no shaft play). Am I missing a line? I routed my vaccum lines as follows:
Intake manifold------T-------BOV
The T goes to another T (shown below)
then turbo compressor nipple-------T-----mbc------tial wastegate
Is there somthing wrong with the wastegate maybe?
