Old 08-31-2009   #1
redline
redline's Avatar
Drives: GSX
DSM link v2?
I am just getting into tuning on DSMlink (V2) and I am having a odd idle problem that I am wondering if I can fix with DSMlink. The car has the idle set at 980 now ( dsmlink ) and I only see that idle when the clutch is pressed to the floor. When the car is in nuetral it will idle around 15-1600. It seems like it is a switch issue, so I am wondering if I enable the idle switch from the TPS sensor instead of the standard idle switch operation, if that would make any difference?
redline is offline   Reply With Quote
