Old 09-08-2009   #1
SkipDag
SkipDag's Avatar
K-Sport Clicking & Craking
Hey all,
I recently had the K-Sports put on my 92 Talon and after roughly 3500 miles I have a pronouce Click and or Crack in the front when I go over light bumps and anything that makes the suspention flex also it will do it during turning. I took it to a local shop thinking I had I big problem, and they told me that the pillow ball is shot on both the Fronts or what looks like a really cheep one that comes with the K-Sports. So I was wondering what would be the best thing to do. There are pillowballs mounts you can pick up from K-Sport. Just looking to see if antone else has had this issue, and if so what to try.
SkipDag is offline   Reply With Quote
Old 09-08-2009   #2
Re: K-Sport Clicking & Craking
K-Sports are cheap coilovers and they have very high failure rates. Contact them and see if they'll send you new pillowball mounts.
Old 09-08-2009   #3
mike55112
mike55112's Avatar
Drives: 04 evo
I have the same problem with my ksports. I have maybe 2000 miles on them.
03 as evo-sold
04 bby ssl-sold
05 ww mr-sold
03 tb evo- current
Old 09-08-2009   #4
Flipboi89
Flipboi89's Avatar
Drives: 2gnt
Same here so what is exactly the problem then?
Flipboi89 is offline   Reply With Quote
Old 09-08-2009   #5
twack
It was a auto get over it
twack's Avatar
yet to see a person happy with long term success with the k sports
Old 09-08-2009   #6
There is a big nut on top of the shocks, make sure that is tight. All of mine have backed off at one point and made the clunking sound.
Old 09-08-2009   #7
4seasons69
4seasons69's Avatar
i've been running my k-sports in my 1g for a year and a half and at least 5k miles now with no problems
Old 09-08-2009   #8
It is the front springs making the noise. When you turn the wheel the shock body rotates but the spring does not want to turn with the body. They have a kit that is designed to fix the problem, its basically a flat roller bearing to reduce the turning friction applied to the spring.
Old 09-09-2009   #9
SkipDag
SkipDag's Avatar
Yes it is the front springs, and the problem does occur when the shock body rotates in fact know that you write this that is almost exactly what the shop said it was. So a kit you say. I imagine it can be found on the K-sport site? Also I will look into the big nut on the top of the shock.
thank you for all the replys
Aaron K.
Old 09-18-2009   #10
Jaei Sun
4G63 X 2 = 8G63
Jaei Sun's Avatar
Drives: 06 EVO, 92 TSi AWD
What does KSport call this kit?
Old 09-19-2009   #11
From my understanding they don't have a kit, just a noise reduction update.
