Old 09-08-2009   #1
thom1301
96 Talon Tsi AWD, 5-spd, 117K miles
’96 Talon Tsi, all-wheel drive (great for the winter!), turbo, 5-speed, black with gray leather, moonroof, 117,xxx miles. It’s cleaned up and ready to go. Price is $3,995.
I’ve owned it since 78,000 miles, since then it’s had synthetic Mobil 1 every 3,000 miles. I’ve done the timing belt and water pump, spark plugs and wires, fuel filter, and synthetic fluids in the transmission, transfer case and rear end. It received a couple front-end parts, a four-wheel alignment, four KYB struts (stock springs), and poly swaybar bushings last year.
Power upgrades include a full 3-inch stainless steel exhaust (with catalytic converter) Magnaflow muffler and stock tips. Has a poly front motor mount, hard intercooler pipes, hard intake pipe with open-element air filter, Greddy internally vented blow-off valve, a manual boost controller and a boost gauge in the glove box. (Link to exhaust install and dyno article)
Unfortunately, there’s a dime-sized rust spot atop the windshield, some under the hatch and where the hatch meets the rear fender. There are also scratches and a couple ripples on the rear driver’s side wheel well, a ding in the hood, and only one fog light. If I get ambitious, I may fix the rust, reinstall the fog light and/or shampoo the carpet.
Link to Pics
I would trade for a '97-01 Jeep Cherokee (not grand), with the Chrysler 8-1/4" rear (essential) and the full-time 4wd option (would be nice).
thom1301 is offline   Reply With Quote
Old 09-08-2009   #2
95tsi
95tsi's Avatar
Drives: a pos
Re: 96 Talon Tsi AWD, 5-spd, 117K miles
Are you talking full time 4wd or just the option? If you want a Cherokee with full time 4wd, they never made it. The full time is only found on the Grand Cherokees. If your looking for the optional t-case it is the NP242 model(select trac I think) and selectable between: 2wd, fulltime 4wd, part time 4wd, N, 4lo.
Just a heads up on the Jeep portion of your ad.
Old 09-09-2009   #3
thom1301
Yep, I'm looking for the 242. Seeing it mostly in Limiteds so far.
Old 09-09-2009   #4
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
I have a cherokee with full time 4wd...
Style's automotive engineer
Old 09-16-2009   #5
thom1301
Sale pending.
