Old 09-09-2009   #1
TurboDomestics
TurboDomestics's Avatar
Anyone else ever get the compressor tester hose stuck in their cyl head
I was trying to test the compression on my 2g, and the hose is stuck in there now! It just spins in place. I got frustrated with it and just left it in there. But I'm going to have to get it out eventually. Any one have any ideas?
4G63 0, Charlie 3
Old 09-09-2009   #2
4seasons69
4seasons69's Avatar
Re: Anyone else ever get the compressor tester hose stuck in their cyl head
I've never had that happen. kinda sounds like its stripped
Old 09-09-2009   #3
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Is it the fitting or adapter like a quick connect spinning or the actual threads in the head where the plug threads into?
Amsoil Dealer
Old 09-09-2009   #4
4seasons69
4seasons69's Avatar
thats a good question. I was thinking about my compression tester the quick connect is at the top for the gauge and the threads are crimped to the hose so if you twist with the hose on mine it wouldn't be the quick connect
Old 09-09-2009   #5
jhaan_dude
jhaan_dude's Avatar
Drives: a car
its the harbor tool and freight type, just pull up really hard while you rotate it, i got one stuck and thats how i got it out...
Old 09-09-2009   #6
A little less cow bell next time you thread the hose into the head, the threads do most of the sealing and the o-ring takes care of the rest. It sounds like the hose is turning but the threaded part is not. So pull really hard and turn or pull hard enough to pull the hose off the threaded part, then use a needle noise vice grip to pull the fitting out of the head.
Old 09-09-2009   #7
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
That is what I was thinking also. I never tried to get it really tight on my car due to the possibility of not getting it out.
7/25/09
Old 09-10-2009   #8
Mwolf83
Drives: 91 Eagle Talon AWD, 02 WRX, 97 Civic Hatch
I've had that happen before many years ago, it was from using a cheap Summit brand comp tester. I do remember having to dig down in there and cutting the hose out of the way and using a socket or a long skinny wrench and reaching down in and removing it. It was the two pieces of the gauge itself that were supposed to not ever spin but had loosened up and would spin. Of course not before I put it in there and I didnt screw it in hard at all.
Mwolf83 is offline   Reply With Quote
Old 09-10-2009   #9
Nartanian
I will eat you aliiiive!!
Nartanian's Avatar
Drives: 1992 Galant VR-4
Sounds like this problem. Hope this helps.
http://www.mnsportcompacts.net/forum...ht=compression
Just some corn and a MBC. Try it. You'll be amazed.
Nartanian is offline   Reply With Quote
Old 09-10-2009   #10
cmspaz
Walls need hugs too
cmspaz's Avatar
LOL Taras.
Originally Posted by Trogdor
Old 09-10-2009   #11
TurboDomestics
I havent tried pulling up on the hose yet. Im gonna go try now!
thanks for the help guys, well see what happens. Weird thing I only hand tighten it, like I normally do.....
4G63 0, Charlie 3
Old 09-10-2009   #12
Same thing happened to me, pulling and twisting didn't get it out, so I had to go buy some super long needle nose pliers to get it started.
Old 09-10-2009   #13
I had this happen ones, so I grew my finger nails out for a few months then got it undone with just my nails.
Old 09-10-2009   #14
TurboDomestics
So I tried pulling it out and all I did was tear the hose. Guess I gotta throw my nail clippers away now.....
4G63 0, Charlie 3
