Old 09-27-2009   #1
2.SlowES
2.SlowES's Avatar
Trans problem
I just swapped in a new (used) AWD trans in my 1g Talon, and now I'm running into some unusual problems...
While under acceleration it feels as though my clutch is slipping (RPMs build and the car doesn't accelerate with it), I'll get an odd pulsing which feels like it's coming from the rear, and it will make a grinding noise if I give it any amount of throttle.
Any ideas on what this could be?
The clutch, rear end, and transfer case were all just fine before I swapped in this trans.
I was told to try and adjust the shifter cables becase it could be caught between multiple gears, does this sound plausible?
2.SlowES is offline   Reply With Quote
Old 09-27-2009   #2
aaronspeed
Drives: 1991 Eagle Talon AWD
Re: Trans problem
I would say the shifter cables need to adjusted correctly to start with and then if you still have a problem I would say the transmission has internal problems.
aaronspeed is offline   Reply With Quote
Old 09-27-2009   #3
2.SlowES
2.SlowES's Avatar
Re: Trans problem
Is it normal to have to adjust the shifter cables after changing out trannies though? Everything was fine before I swapped this other one in...
Old 09-27-2009   #4
blackrosenova400
blackrosenova400's Avatar
Re: Trans problem
If your tranny was caught in multiple gears, your tranny would blow instantly, and its not really possible unless a shift fork roll pin was broken.
Old 09-28-2009   #6
2.SlowES
2.SlowES's Avatar
Re: Trans problem
Look at your clutch fork that your slave cylinder pushes on, tell us if its more towards the passenger side or the drivers side.
It was fairly centered, but more towards the passenger side.
Old 09-28-2009   #7
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: Trans problem
Is the transfer case output shaft splines on the new tranny rounded causing the shaft to ratchet in the t case?
Amsoil Dealer
Old 09-30-2009   #9
2.SlowES
2.SlowES's Avatar
Re: Trans problem
Hey guys, I figured out what was going on. The transfer case was toast and was causing all the problems, and thats what actually took out my tranny I'm guessing. Luckily I had a spare t-case sitting around, so we swapped that one in and everything worked fine!
Thanks for all your help guys!
Old 09-30-2009   #10
95talonracer
Finally Tuned...
Drives: Spyder GSX
Re: Trans problem
Ahh i knew it! Good to hear.
Amsoil Dealer
Old 09-30-2009   #11
2.SlowES
2.SlowES's Avatar
Re: Trans problem
The splines weren't rounded, the t-case was just F'ed haha.
