Old 10-08-2009   #1
91laserrs
Drives: 91 Laser rs 16g almost 300hp
Please Help! Car wont start at all an ran fine a week ago
Ok i have a 91 plymouth laser that i bought from a guy an it was fine until the tranny went so it took me forever to find a fwd dsm tranny. then i finally found one the other day at the junk yard. so today with a little help from the bro we finally got it changed. got everything done. an now it wont start WTF? i started it periodicly and then switched the tranny a nothing. cant figure it out. cant hear the fuel pump but when i pulled off the return line there was fuel but only when cranking? doesnt seem right. there is spark cause it will sputter if it sits for like a couple seconds then fires a little then jus turns over. does it over an over. hooked up all vaccume lines an double checked the wiring an i dont kno what could be wrong??????
Please post a response an let me kno what you think anything will help.
thanks
91laserrs is offline   Reply With Quote
Old 10-08-2009   #2
deadeye
deadeye's Avatar
Drives: 95 TSi AWD POS
Re: Please Help! Car wont start at all an ran fine a week ago
make sure all the grounds are attached. make sure all the connectors are tight. its pretty easy to overlook that stuff when your doing a big job like that but its almost always the case that something was not re-attached or plugged in all the way.
deadeye is offline   Reply With Quote
Old 10-08-2009   #3
91laserrs
ya thats what i did for like an hour an i cant think of anything. can you think of anything for certain like which plug?
Old 10-08-2009   #4
deadeye
deadeye's Avatar
well, there is a couple. The cam angle sensor, the ignition pack(transistor pack), the mass airflow sensor, throttle posistion sensor. I cant remember for sure if 1g's got it, but there should be a ground thats held on by a starter bolt thats easy to misplace when dealing with all that stuff. the ground between the head (could be the intake manifold-cant remember) and the body, the ground between the body and the battery.
My own personal demon was the connector to the transistor pack. It seemed like I had to really actually try to push that one on.
Old 10-08-2009   #5
91laserrs
ya i didnt mess with an thing like the cas or the ignition coil an i connected the starter ground. this might seem like a dumb question. should i be able to hear the fuel pump when the key is on? like the typical quick little noise from the tank??
Old 10-08-2009   #6
Nartanian
I will eat you aliiiive!!
Nartanian's Avatar
Drives: 1992 Galant VR-4
Maybe you should take a look at the ECU since it sat so long.
Just some corn and a MBC. Try it. You'll be amazed.
Nartanian is offline   Reply With Quote
Old 10-09-2009   #7
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Broken wires to the coolant temp sensor?
Old 10-09-2009   #8
GREASEMONKEY
GREASEMONKEY's Avatar
Moon Lander Champion!
Drives: 92 TSi
Where are you located? I might be able to come check it out if your not too far from Minneapolis..
PM me if you want to figure somethin out, Maybe i can help you out..
-Stephan
Old 10-09-2009   #9
allyoucaneat_talon
allyoucaneat_talon's Avatar
Drives: 93 Talon Tsi AWD
Sounds kind of funny, but it looks like a bad head...Mine was doing that also...check everything that people been saying.. Do a compression Test, because your car might of been sitting a little long.
95 Talon Tsi= SOLD
92 Mitsu Gsx= SOLD
Old 10-09-2009   #10
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
Being it sputters I would say coolant temp sensor also.
Old 10-09-2009   #11
carltalon
carltalon's Avatar
Drives: 98 Eclipse GSX Auto
I had a similar problem when my car sat for a few weeks whule I painted it. Turns out to of my injecters were stuck shut. took my forever to figure out since everything seamed fine. Probly not as likeky if you not runnung 1600cc injectore but something worth checking.
11.35 @ 120mph
Old 10-10-2009   #12
91laserrs
alright thanks im gunna try the coolant temp sensor? so that would make it not start? an ya i think i did break it cause pulling the tranny mount off i punched it by accident.
Old 10-10-2009   #13
91laserrs
i think i did break the coolant temp sensor. so that would make it not start?
Old 10-12-2009   #14
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
It could
Old 10-12-2009   #15
desolate
91 TSi AWD
desolate's Avatar
Drives: red 91 TSi AWD auto
Make sure you have all the positive and negative leads attached to the battery. Once before I had problems with starting and it was from a loose positive lead. I've also had an ecu go out and that caused no start as well. Usually if all things are fine I'd check that. If you have a fuel pump rewire check to see if you attached it back on.
Old 10-12-2009   #16
91laserrs
It was the coolant temp sensor finally got it running today. thanks for the help. Now does anyone have a recirc hose??
Old 10-12-2009   #17
4seasons69
4seasons69's Avatar
from the bov to the intake?? I think I have one for a 1g
Old 10-12-2009   #18
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
No problem
Old 10-23-2009   #19
Alpha D
Got Boost o_O'' m
Alpha D's Avatar
WOW A COOLANT TEMP SENSOR CAN PUT YOUR CAR ON ICE LIKE THAT!!! My goodness i better check all my sensors, and grounds. My car wouldn't start after a manifold swap! Embarrassing enough turned out to be a missing bolt in the manifold and mis matched distributor plus ^_^....Now all that is left finding another vacuum leak and im good to go!!
Say does anyone know where i can get a boost leak test kit from??? I wanted to build one but its so hard finding the parts....
Old 10-23-2009   #20
Home Depot will carry everything you need to make a boost leak tester.
