Old 11-15-2009   #1
rose0529
Who has my man-card?
rose0529's Avatar
Drives: a red car
tire size quuestion
we are looking at snow tires for the mini, we have an extra set of 17s for it but the size that fits (205 45 17) the cheapest is $140ea. is a 205 50 17 (3% larger) gonna be bad? they are $91ea
Old 11-15-2009   #2
rose0529
rose0529's Avatar
Drives: a red car
Re: tire size quuestion
i know the spedo will be off a couple mph, but is there anything else i should be worried about?
Old 11-15-2009   #3
The speedo will read low, the car won't feel quite as peppy, and its possible (but not likely with stock suspension) that the tires will rub at full-lock.
Old 11-15-2009   #4
polishmafia
Smells like cat poop
polishmafia's Avatar
Like Kracka said, your speedo with read low. At 60mph on the speedo you'll be going about 62.
The overall diameter of the 50 series tire will be just under an inch bigger than the 45 series tire with a 205. Unless the clearance now is super close, I doubt you will rub under normal driving conditions.
Old 11-16-2009   #5
I would think you would be just fine with the 50's.
Old 11-16-2009   #6
rose0529
rose0529's Avatar
Drives: a red car
Thanks guys! Thats what i was thinking just wanted to double check!
Old 11-16-2009   #7
CarPsyco84
CarPsyco84's Avatar
I did that on my wife's car, but like a 5% larger diameter. You won't even notice the difference driving it, just have to remember when going on the highway that its gonna read slightly low, but 3% is really slight, your speedometer might have been off by more than that from the factory.
-When in doubt, Moar RPM.
