Old 11-15-2009   #1
Looking to make a T to measure Oil psi at turbo
I need a t or some contraption that will allow me to measure oil psi at the turbo.
The turbo fitting has to be a 12x1.5 fitting, i am using a 12x1.5 to -4an fitting with the -4an side milled and a nitrous jet as a restrictor so what ever T i come up with also has to accept a 12x1.5 fitting as to measure the oil psi after the restrictor.
Any ideas, just wondering because i ruptured my brain looking at industrial sites for fittings.
Thanks
Aaron
Old 11-16-2009   #2
v8klla
v8klla's Avatar
Re: Looking to make a T to measure Oil psi at turbo
If this works you owe me lunch
http://www.atpturbo.com/mm5/merchant...gory_Code=GTBB
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 11-16-2009   #3
lol, nice try, but it doesn;t accept a 12x1.5 fitting.
Old 11-16-2009   #4
Make an adapter. I'd think the pressure there wouldn't be very much since it's going from high pressure to very low (the drain tube).
Old 11-16-2009   #5
um, thats where im needing the help sourcing the fittings
Old 11-18-2009   #6
Get an inline AN fiitting with some sort of female NPT fitting.
Basically, it'd go in line of your AN feed line, and has a NPT outlet and connect a gauge or whatever.
www.anplumbing.com
Old 11-19-2009   #7
Thanks for the effort I found the perfect contraption for less than $15.
