Old 11-24-2009   #1
travail
travail's Avatar
Drives: EV0 8
RX7 4G63 swap
I was thinking of doing a 4G63 swap in to a rx7 FC. What RWD transmission can I run or should I make it AWD.
Old 11-24-2009   #2
polishmafia
Smells like cat poop
polishmafia's Avatar
Re: RX7 4G63 swap
Call MAP, they might know. :P
Old 11-24-2009   #3
caffeinetripp
DSM's Dead
caffeinetripp's Avatar
Drives: '91 Dakokta
Re: RX7 4G63 swap
http://www.projectzerog.com/transmissions.shtml
'92 MX-3 KLZE Swap, I/H/E, battery relocate.
caffeinetripp is offline   Reply With Quote
Old 11-24-2009   #4
travail
travail's Avatar
Drives: EV0 8
Re: RX7 4G63 swap
Originally Posted by caffeinetripp View Post
Thanks
Old 11-24-2009   #5
Re: RX7 4G63 swap
Use the T56 it would be heaven
Old 11-24-2009   #6
viridionplague
Re: RX7 4G63 swap
t56 for sure, they are amazing beasts, viper spec if you can :P
Old 11-24-2009   #7
Re: RX7 4G63 swap
Impossible!
...jk...Def check map's setup out :P
Old 11-24-2009   #8
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: RX7 4G63 swap
Use the turbo II trans with a mazda B200? i think it is bellhousing.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 11-24-2009   #9
Re: RX7 4G63 swap
a T56 can hold some power for sure, but can they shift at high revs?
Old 11-24-2009   #10
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
Re: RX7 4G63 swap
Sure they can. I once went from 2nd to 1st in a Viper no problem, at like 70. Oops.
Old 11-24-2009   #11
travail
travail's Avatar
Drives: EV0 8
Re: RX7 4G63 swap
My old rx7 had a LT-1 with a T-56. I was shifting at 7600 RPM with the LT-1 and It was not a stock motor.
Old 11-24-2009   #12
Re: RX7 4G63 swap
You should just do a swap like you had in your old rx7, that thing with a big shot just wasn't fair haha.
Old 11-24-2009   #13
travail
travail's Avatar
Drives: EV0 8
Re: RX7 4G63 swap
It seem like ever one is doing a V8 swap. I just wanted something new something you do see ever day.
Old 11-24-2009   #14
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Re: RX7 4G63 swap
Well, map already has a 4g63 FD. You might be the first to do it in a FC, but who knows. Why not just do the V8 swap that is proven and swap parts are readily available. I considered doing a rx7 v8 swap to use as a road race car.
7/25/09
Old 11-24-2009   #15
Re: RX7 4G63 swap
Nope, i've seen FCs with 4g motors too.
Old 11-24-2009   #16
D_Venable
SQ addict
Drives: 85 and 88 Conquest (plus a 2011 Silverado)
Send a message via AIM to D_Venable
Re: RX7 4G63 swap
the B2600 bellhousing will mount to the RX7 tranny. BUT only the 87 and 88 model years.
The 87 and 88 Mazda B2600 had the Mitsubishi G54B motor
BUT your 4G would need to be a wideblock
D_Venable is offline   Reply With Quote
Old 11-25-2009   #17
Re: RX7 4G63 swap
You should do a 4g63 swap in a gremlin. That would be awesome.
Old 11-25-2009   #18
Re: RX7 4G63 swap
Yeah, gonna be tough to find something new in a FC, although my friend has something new once we find a shell.
Old 11-25-2009   #19
Re: RX7 4G63 swap
Yea I did the 3rd to second once. Third gear in a viper winds out about 120 mph so it was a little much for second gear
