Old 04-12-2004   #1
tsiawdspeed
tsiawdspeed's Avatar
Send a message via AIM to tsiawdspeed
I installed my new suspension consisting of AGX's and Prokits in my car (2G) this weekend. The ride is pretty damn nice. It handles a LOT better. Almost no body roll on some corners. It looks a whole lot better. I also got an alignment and everything is where it should be except for the camber which is off by .5 degrees. One strange thing I noticed is that the rear shocks are only 4 position adjustable and you adjust them on the top of the shock shaft just like the fronts. Also, if anyone knows the length of the stock 2G front shock body, could you let me know so I can compare to the length of the front AGX body? I know the new style 2G front AGX is noy at least the same length as the stock shock if not shorter. And if anyone is wondering, the new correct front shock part # is 741042. Anyways, I thought I would share with you guys :3gears:
tsiawdspeed is offline   Reply With Quote
Old 04-12-2004   #2
CVD
Sten Sniper
CVD's Avatar
Drives: Evo VIII RS
Send a message via AIM to CVD
Congrats man, you planning on doing any racing this year? AutoX, AARRF, or otherwise?
Old 04-12-2004   #3
tsiawdspeed
I will be doing some drag racing sometime over the summer, preferably before and after I get an exhaust. I dont know about autox, although that sounds like a lot of fun.
Old 04-12-2004   #4
Pictures, please!
Where did you go to get your alignment done and what did they charge? I've heard of a lot of local places charging outrageous amounts of money if your car is lowered and/or has aftermarket suspension pieces.
Old 04-12-2004   #5
tsiawdspeed
I will post pictures in a few weeks because I just went back to school. I have some really shitty pictures of the wheel gap but thats it. I got my alignment done at Southcross Auto in Savage. I took it there because I have been there quite a few times before and they do really good work. I had them install the front shocks also because I could not get the sway bar end links off for the life of me. They charged $80 for an alignment which I think is a little high. Oh well, they did a good job.
