Old 12-09-2009   #1
93gtpeater
Drives: cbr 1000rr repsol
1g awd tranny noise
So I took the car out tonight to see how the acted in the snow. And so when I get on it the ass end slides out. But the front tires aren't spinning that I could tell. Is this normal for it to do that in the snow. is the center diff broke? Or is it just slipping cause the power and road condition? Just wondering if I should start with building a tranny before buying new parts.
Old 12-10-2009   #2
Re: 1g awd tranny noise
How do you know if the front wheels weren't spinning?
Old 12-10-2009   #3
I would say put in on jackstands and see for sure if the front wheels are spinning, have a friend take a look while you're giving it gas in gear with all four wheels off the ground
Old 12-10-2009   #4
Open front diff. Good chance one isn't really spinning if the other one is allowed to spin and the rear tires are "driving" the vehicle. As mentioned, how are you showing the front tires aren't moving?
Old 12-10-2009   #5
93gtpeater
When I got home I dropped the clutch in my driveway and from the marks it was just the rear tires spinning. Nothing from the front. You could see the tread pattern perfectly
Old 12-10-2009   #6
GnArKiLl
GnArKiLl's Avatar
VC starting to go?
03 Evo VIII
95 Talon AWD-wire tuck,6bolt,holset powered,E85
95 Nissan 240sx KA-T
93 Eagle Talon-5spd swap,wire tuck..SOLD
Old 12-10-2009   #7
93gtpeater
What's vc?
Old 12-10-2009   #8
viscous coupler
Old 12-12-2009   #9
93gtpeater
Ok so I took the talon out today. And it makes the noise even when I rev it up. With the clutch in and out. I did a couple pulls and in third gear it was fine no nosie half the time. All four hooked. But in lower gears it always made the noise. And felt like the rears tires are spinning.
