Old 12-11-2009   #1
aaronspeed
Drives: 1991 Eagle Talon AWD
Brake Master Cylinder NON-ABS
What is the difference between the ABS and Non-ABS units? Is the flange to the vacuum unit the same width. I can not find any dimensions to compare and no parts store has both units in stock to get a look. I did find that the bore of the units are the same. The only other difference could be the springs inside the unit are weaker or stronger for the ABS control box.
aaronspeed is offline   Reply With Quote
