Old 12-29-2009   #1
thesoccadude
4g63t in my mirage sedan? fwd.
so i have a mirage es with an auto. i've read on mirageforums.net but am not really understanding. if i want to swap in a 4g63t with a 5 speed, what should i use and what do i need as far as motor mounts, transmission, ecu, etc??
i'm looking at a fwd considering awd is way out of my budget.
thesoccadude is offline   Reply With Quote
Old 12-29-2009   #2
Ihearrtdsm
Hello Panduh
Ihearrtdsm's Avatar
Tic Tac Toe Champion!
Re: 4g63t in my mirage sedan? fwd.
what generation you have?
Old 12-29-2009   #3
thesoccadude
sorry, it's a 4g. 1993 mirage es sedan with a 1.8 auto.
Old 12-29-2009   #4
Ihearrtdsm
Hello Panduh
Ihearrtdsm's Avatar
http://www.mirageforums.net/viewtopic.php?f=52&t=15567
^ What I gathered from this is: Dsm motor, tranny on the forum above said 1.5l and 1.8l work, evo 1-3 motor mounts, ecu, wire harness, and sensors(I'm probably missing some stuff).
http://www.mirageforums.net/viewtopic.php?f=52&t=793
hope this helps!
Old 12-29-2009   #5
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
4g61t.org would have some good info.
-1990 Mitsubishi Cyborg 4WD-
Old 12-29-2009   #6
A pm would have worked also or you could have looked at the coupe that I built. But any way
91-94 ecu
91-94 engine harness
Make a boom sling harness to go from mirage to dsm for the dash
2g block mount
2g upper engine mount
1.8 auto tranny moint
1.8 auto tranny frame rail mount
2g turbo fwd tranny
Mirage tranny roll stop mounts bolted to the 2g tranny
1g gsx front axels both sides
You also can use a 1g tranny with custom mounts. That is what I did to mount a awd 1g tranny in the 95 coupe.
It is not that hard of a swap to do.
It is a lot easyer with evo 1-3 wiring. (I have a engine,dash,engine bay harness laying around)
If you need more info on doing it just ask me.
4g61t will not tell you nothing at all that is just for 3g csm's not the 4g's
Old 12-30-2009   #7
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Ahh, my bad. I figured they were very similar.
Old 01-21-2010   #8
Chim55117
Drives: 2007 BMW 335i Coupe
do i need a 6 or 7bolt considering evo 3's were 7? tkr, pm a price on the harnesses.. anyone ever do a straight auto 4g63t swap into a mirage?
Chim55117 is offline   Reply With Quote
Old 01-21-2010   #9
no one has done a auto swap
you can use a 6bolt or 7bolt
you need to use the mirage tranny with a n/t fly 4g63
or
2g fwd 4g63 tranny
I would take for the evo harness
125.00 engine harness
50.00 dash harness and part body
75.00 for the engine bay harness
Old 01-22-2010   #10
thesoccadude
so if i took an auto 4g63t out of a 2g it could swap in pretty easily?
Old 01-22-2010   #11
any 4g63 will work it does not matter 6 bolt or 7bolt
Old 01-25-2010   #12
thesoccadude
how did you switch 1g awd tranny to work on this?
Old 01-25-2010   #13
Have to make new front and rear rollstop mounts. Rework the roll stop brace. And have to use a 90 awd tranny with a weleded center diff.
Old 01-25-2010   #14
thesoccadude
would everything work the same if i used a 2g auto tranny?
Old 01-25-2010   #15
No one has ever done a full auto swap. Every one goes to 5speed. But it should work just fine. You would need to use the 2g auto engine harness then and ecu and tcu too get it all to work right
Old 01-25-2010   #16
thesoccadude
anyone have a 2g tranny? if not i'll go auto.. if i went auto, what part of your evo harness would i need?
Old 01-25-2010   #17
With the auto you would need to wire the full car with the dsm harness and make it all work right. I would just get a 5 speed tranny 2g fwd or 1g fwd. I can make the mounts for the 1g tranny in a few hours
Old 01-25-2010   #18
There is a fwd 2g auto tranny for sale in the classifieds right now.
Old 01-25-2010   #19
thesoccadude
yeh.. i'm looking for a 5spped preferably..
