Old 01-20-2010   #1
TurboDomestics
TurboDomestics's Avatar
2g eprom chip.
Ive got a socketted eprom ecu and something isnt working. If anyone has an eprom chip that will work just to see if the rest of the ecu is ok I would love to buy it off you or borrow it real quick.
4G63 0, Charlie 3
Old 01-21-2010   #2
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
Re: 2g eprom chip.
I have a factory eprom chip sitting here if you didn't find one already. The only problem is that I am not sure if it was off a 1g or 2g. The numbers on the sticker say EB23D and under that it says 4826. I tried to research for a few minutes but couldn't figure out which it is from. If it will work for you, let me know and you can have it. The black chip also says 270512-12 BLUP9318351.
Otherwise, Ryan (mustgofaster) used to be able to burn chips and could possibly burn you one with your settings. There are probably others on here that can burn them as well.
7/25/09
Old 01-21-2010   #3
jrohner
jrohner's Avatar
Re: 2g eprom chip.
EB23 would be a 2G.
Old 01-22-2010   #4
TurboDomestics
Re: 2g eprom chip.
thanks a bunch! just picked it up.
4G63 0, Charlie 3
