Old 01-28-2010   #1
dsmdion
dsmdion's Avatar
N/T 6 bolt
Ok so i have a 95 tsi awd that i picked up where the pistons hit the valves. Problem is the kid left the car sit with the head and everything off, and the engine kinda rusted out. I have a perfectly running N/T 6 bolt 4g63 GS that i drive, and i was thinking about running that motor in my tsi awd. Now if i drop in some turbo pistons (not worried about having oil squirters) and put some turbo cams in the head should that take care of everything? also what is the install like as far as matching up the turbo parts. I have all the turbo parts on the talon do I just swap the shit over, and install it like a 6 bolt in a 2g or what? anyway just figure id ask to see if someone who has done it, It doesnt seem to hard from what i read, but things never go as easy as you think lol, and just wondered if you would have any pointers
Thanks!!
dsmdion is offline   Reply With Quote
Old 01-28-2010   #2
twack
It was a auto get over it
twack's Avatar
Re: N/T 6 bolt
It all matches up you just need to install a knock sensor in the block, or you could disasemble the block in your car and have it all hot tanked at a machine shop
Old 01-28-2010   #3
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Re: N/T 6 bolt
Thanks!!
Whats up Dion? That 6 bolt motor will work like Twack said. The only things I would watch out for is to make sure you're using a 1g intake manifold with that 1g head. Basically, the whole thing should be just like a 6 bolt swap into a 2g.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 01-28-2010   #4
dsmdion
dsmdion's Avatar
Re: N/T 6 bolt
whats up dustin, well thats good news then, i was kinda researching it and it sounded like it would work, no ill just have to find another car to drive around for a few days.
Old 01-28-2010   #5
twack
twack's Avatar
Re: N/T 6 bolt
i got a NT engine in one of my AWDs let me know if you need help
Old 01-28-2010   #6
123abc
123abc's Avatar
Drives: Loud cars
Re: N/T 6 bolt
For sure. If you need help wrenching, hit me up. I'll be glad to help.
Old 01-28-2010   #7
dsmdion
dsmdion's Avatar
Re: N/T 6 bolt
ok sounds good, ill let you know, ill prolly need a little help, im gonna try to get some shit figured out with getn a dif. car so i can pull the motor out of the gs, and still be able to get to work and school.
