Old 01-28-2010   #1
travail
travail's Avatar
Drives: EV0 8
Turbo oil feed restrictor fitting
I heard that you need to have one if you have a ball bearing turbo is this true and what will happen if you are not running one.
Old 01-28-2010   #2
Jungy
Jungy's Avatar
Re: Turbo oil feed restrictor fitting
If you don't run one your turbo is going to see oil pressures higher than what they are recommended to run at and eventually the seals will blow out in the center section.
Old 01-28-2010   #3
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
it also depends on where you are getting your feed from
or it matters on 1g/2g anyway. Best place is to get feed from for BB is the cylinder head. I don't know how Evo's work...
Old 01-28-2010   #4
slowbubblecar
Big Turbo Monster
slowbubblecar's Avatar
Drives: GTS and E55
I don't know about that... Check with your turbo manufacturer and see what size restrictor is needed for your turbo. MY GT35R oil line is coming off the oil filter housing and has a FP restrictor.
7/25/09
Old 01-28-2010   #5
slowbubblecar
Big Turbo Monster
Drives: GTS and E55
http://store.forcedperformance.net/m...Lancer-TurboHW
These are some they sell for the EVO. Probably the same as the dsm ones.
7/25/09
