Old 03-06-2010   #1
travail
travail's Avatar
Drives: EV0 8
rod bearings
Well a little info on why I need new ones. I heard this noise it sounded weird under load so I had to look in to it and I found out that my rod bearings were going out it looks like the metal was flaking off (I had a bad oil pump and I didn't know it) so I am looking in to getting new ones what kind should I look in to.
Old 03-06-2010   #2
Re: rod bearings
Get a set of acl race bearings
Old 03-06-2010   #3
Re: rod bearings
How does the crank look?
Old 03-06-2010   #4
travail
travail's Avatar
Drives: EV0 8
Re: rod bearings
It look good I will post pics later of it.
Old 03-06-2010   #5
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
Re: rod bearings
I would make sure that the crank is good and not just look it over quick and slap in new bearings and call it good.
Amsoil Dealer
Old 03-06-2010   #6
travail
travail's Avatar
Drives: EV0 8
Re: rod bearings
I am going to have some one look at it for me.
Old 03-07-2010   #7
Re: rod bearings
Keep an eye on it after you put in new bearings, I've never had good luck with turned cranks in DSM's.
Old 03-08-2010   #8
Re: rod bearings
Is that what this was about?
http://mitsustyle.com/forums/showthread.php?t=25800
Old 03-08-2010   #9
travail
travail's Avatar
Drives: EV0 8
Re: rod bearings
No that was really my buddy car.
Old 03-11-2010   #10
CarPsyco84
CarPsyco84's Avatar
Re: rod bearings
I used clevite 77 tri-metal Main and rod bearings. Whatever you get, I would make sure they are tri-metal as opposed to bi-metal, because the galling resistance is like 3 times better.
-When in doubt, Moar RPM.
Old 03-15-2010   #11
travail
travail's Avatar
Drives: EV0 8
Re: rod bearings
well looks like I am putting in a new crank and main-rod bearing and piston ring. I saw that the #4 piston ring look bad so I just going to hone out all the cylinder's and put in new piston ring sent I have the piston out.
Old 03-15-2010   #12
Fran05
Drives: DSM
Re: rod bearings
Busted!!!
Old 03-15-2010   #13
Re: rod bearings
I suggest having John Gosh do the work if you are comfortable pulling the motor out and dissasembling it yourself
Old 03-15-2010   #14
Re: rod bearings
JG would be best, but that job is also pretty easy with a bottle hone and a drill.
Old 03-17-2010   #15
travail
travail's Avatar
Drives: EV0 8
Re: rod bearings
I am getting a 100mm EAGLE FORGED CRANKSHAFT. It the same one as I have and here are the pics of the rings you can see little marks on them.
Old 03-17-2010   #16
Re: rod bearings
Eagle cranks for mitsus are junk. Ask MAP about them.
Old 03-17-2010   #17
Re: rod bearings
If you get an eagle crank, expect that it will need machining out of the box. They usually have a big ol' tag on them right out of the box saying so.
And FWIW, I have only ran King bearings. And so far so good.
