Old 03-13-2010   #1
91laserrs
Drives: 91 Laser rs 16g almost 300hp
1g talon tsi hub needed bad an maybe 16g?
If any of you guys have a right rear hub for a 1g talon tsi. My wheel moves around a lot so I'm pretty sure that is what I need an I have new bearings to put in it so All I need is thE hub assembly. an maybe some other parts like a good slave cylinder for the clutch. Let me kno what you have I'm lookin for parts to get my project on the road comment the thread or pm me. Also if some one could tell me about how much a dsmlink is that would be nice. Thanks
91laserrs is offline   Reply With Quote
Old 03-14-2010   #2
Re: 1g talon tsi hub needed bad an maybe 16g?
What you need is just a rear wheel bearing, go buy new at the store, used bearings would be a waste of money. The hub assembly itself doesn't go bad. I think you do need the bearing pressed into the hub though, can't remember, it's been years and I've done them on hundreds of different cars.
Old 03-14-2010   #3
craig
wants to kick mark
craig's Avatar
Drives: Battery with wheels
yep hubs are pressed.
Old 03-14-2010   #4
Link is $525 if you have an eprom ecu. If you can wait I will be selling mine once I get home.
Old 03-14-2010   #5
91laserrs
Ok jus want to make sure cause it is really bad I ordered the bearings already. Sorry if I sound like a noob. But with the link that have anti lag an I can run the blow off to the atmosphere right?
Old 03-14-2010   #6
yep, I will help u out with it. I'll be back may 4th
Old 03-14-2010   #7
91laserrs
K now I jus need to find a EPROM ecu. N how much u want for it so I can get. the money
Old 03-15-2010   #8
Lets PM to not get too off topic but I have the eprom ECU as well.
