Old 03-14-2010   #1
improper voltage on wrong wires to CAS with AEM
Alright, it ran fine when I parked it in October, I took it all apart and redid a bunch of stuff, but other than putting the wires through a different hole in the firewall, nothing about the harness changed.
But now it wont start. It's not stat syncing, so we checked all the wires to the cas, and according to this:
pin 1 (Larger)Black Ground
pin 2 Red +12v Power
pin 3 White TDC (to ECU pin 22)
pin 4 Black Crank Angle (to ECU pin 21)
What I have is wrong. On both cam and crank signal wires I have 5 volts, and nothing on the others (or 5 on the power wire, it's all a blur right now).
With the big plug unhooked, I tested voltage at the ecu and both signal inputs for the CAS showed 5 volts, I didn't look for 12v for the power wire, I'll get on that tomorrow.
Anyway, the car's ready to start, just have this problem.
