Old 04-17-2004   #1
Kougar
Drives: 06 RSX
Ok, so i got my quest. Now i have a 1g bov. After the install, it's leaking boost after like 8 PSI or something. It also dies after going off WOT, starts bad, and well...it's not running good. So i know i need to crush it, like i assumed i would. But not quite sure how to crush it. ALso, can i do it without a vacuum pump? I know you crush the top of it down with a vice grip after you connect a pump until you get the desired pressure limit on it (aka boost cut basically).
If all of that made no sense, or even if it did, just tell me how to crush a bov.
