Old 03-21-2010   #1
1g Dual piston Calipers.
Ive decided being that the current front rotors are rusted bad enough that its time i upgrade the calipers to the slotted rotors i have. But i need the 1g dual piston calipers.
Anyone doing a partout or have a set of these?
Thanks
Tom
Old 03-21-2010   #2
iceminion
iceminion's Avatar
Re: 1g Dual piston Calipers.
PM'ed
building a 3000GT AWD Turbo.
Old 03-21-2010   #3
Ill take em. Thanks
Old 03-21-2010   #4
U pull it has them and they are under 25.00 for the set.
Old 03-21-2010   #5
Problem would be finding a 93-94 that still has them though. and ones that arent seized or some shit.
Old 03-21-2010   #6
lol, ^He'll sell them to you for $50 a set. lol
Old 03-21-2010   #7
I get them there all the time and they do come on other mitsu other than just the 93/94 awd's I pick them up clean the up and sell them to the mirage guys.
Old 03-21-2010   #8
^This guy is J yard king, I think they come on the diamante as well.
You can upgrade the mirages with these?
Old 03-21-2010   #9
They do come on the diamante's that is what I get them off of all the time. They bolt right on to the mirage's. That is what I am going to do with the new sedan and I put a set on the hatch for the wife.
Old 03-21-2010   #10
Constant_Project21
Constant_Project21's Avatar
Drives: E36
They also come on the NA 3/s, if I'm not mistaken.
Old 03-21-2010   #11
That they do and the pistons are a little bit bigger in the 3s n/a's over the dsm ones
Old 03-21-2010   #12
TKR rocks!!!
Do you want an apprentice this summer?
Old 03-21-2010   #13
User Name
Hates blue couplers.
User Name's Avatar
Drives: White 1Gb TSi
No shit. I'd like to bulshit with TKR some day, or at least follow him around at a junkyard. He knows his shit and is always down for lending some good knowledgeable info. Ah feck.
ForSale:
90 OFH+Cooler/AN fittings
FIC 850
FP Turbo kit
Old 03-21-2010   #14
Why not look for the 2g calipers as well?
Old 03-22-2010   #15
Yeah, 2g gsx calipers and rotors are the same as the 1g big rotors and 2 piston calipers.
Old 03-22-2010   #16
2g's use as banjo bolt so you would need to change the brake lines also. all others are screw in brake lines and are a direct swap in
Old 03-22-2010   #17
Oh yeah, forgot about that.
Old 03-22-2010   #18
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
That is only true for the 95's I thought...
Old 03-22-2010   #19
Constant_Project21
Drives: E36
I'm pretty sure all 2g gsx/tsi awd's use a banjo style brake line.
Old 03-22-2010   #20
Correct. and with the amount of rust on this car i really dont want to mess with swapping brake lines, yet.
