Old 03-22-2010   #1
BogusSVO
BogusSVO's Avatar
Drives: 1985 Ford Thunderbird Turbo Coupe
Why NOT to let your head be Belt Surfaced
Why not to let your head be belt surfaced/sanded
The subject head is a Mitsu 4G63T from an Evo VIII
This head was in very good shape to start.
The head was pulled due to a bottom end problem.
It was not overheated.
It was taken to another shop, NOT mine.
The customer was told it was surfaced .003-.004
It was then run and the bottom end failed, Then came to my shop.
The first thing I did was to check the thickness of the head.
I know a belt surfaced head will not be parallel nor square along with not having the proper surface finish for a MLS head gasket.
HN#
Date
CAST#G6EW
NOTES:
IV stock
New thickness 5.200
EV stock
Min thickness 5.185 (AREA SPEC)
EVO 8
Cam Gears
Combustion Chambers
Bolt Holes
4
3
2
1
5
4
3
2
1
10
9
8
7
6
Head Thickness 5.187
Head Thickness 5.184
Head Thickness 5.189
Head Thickness 5.188
If you look at the 4 corners, you will see how the head gasket surface is not parallel to the valve cover rail.
It is close, but still off
This is the surface finish left by a belt sander
This is how the surface looked after I milled appox .002
It did cut most of the surface, but it was still low at one corner, and it would happen to be right around the oil feed port to the head.
I made another pass of about .002
This is how it looked.
I made another .002 cut
And was to this
So one more pass to clean the gasket surface, and proper clamping force will be kept on the head gasket.
I measured the head again, and it was 5.183 at all 4 corners
When I cc’ed a combustion chamber it was 44cc
I also did “oil port mod #1” before I surfaced the head.
This head is now .002 below AREA min spec, but is still a useable head.
BogusSVO is offline   Reply With Quote
Old 03-24-2010   #2
CarPsyco84
CarPsyco84's Avatar
Re: Why NOT to let your head be Belt Surfaced
LOL who ever thinks belt surfacing is a good idea on anything that needs to be even close to flat is high.
-When in doubt, Moar RPM.
Old 03-24-2010   #3
twack
It was a auto get over it
twack's Avatar
i know,! ive beEn using a dremel
Old 03-24-2010   #4
I just beat it flat with a large hammer.
Old 03-24-2010   #5
I just like to beat it.
I belt sanded my turbo fitting, works great for the last year.
Old 03-24-2010   #6
blackrosenova400
blackrosenova400's Avatar
Aww come on that just the wrong way of doing things. OYu should use a brass malet!
20g Mafia
Old 03-26-2010   #7
BogusSVO
BogusSVO's Avatar
I would think there is a bit of diffrence between the surface needed for a turbo fitting (oil return I would guess) and the finish needed for a head gasket...
