Old 04-02-2010   #1
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
WTB: Motor mounts and axles.
need a few things:
The car is a 1992 AWD auto.
I need:
1. Front a back motor mounts. The ones on the sub frame not on the motor.
2. Both front axles with the nuts.
3. The half shaft that bolts to the motor on the left side.
4. Stock AWD exhaust.
5. Stock IC setup.
6. Stock turbo set-up with all of the lines.
7. Tourque converter and flex plate w/ bolts.
I think that's all.
Let me know what you have and how much you want for it.
Nick~
651-270-4132
Old 04-02-2010   #2
Re: WTB: Motor mounts and axles.
I should have both the mounts laying around. will have to look since I am in the middle of moving
Old 04-02-2010   #3
munchgsx
munchgsx's Avatar
Let me know.
Old 04-02-2010   #4
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
I have a stock exhaust for a 1g awd manual. It needs some patching done, but it's complete.
If you come get it in Winona, it's yours.
EDIT: Actually, I think I threw away the cat-forward, let me check on that for ya.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 04-07-2010   #5
munchgsx
munchgsx's Avatar
I'm still looking for this stuff. Mainly the tourque converter and flex plate, also the motor mounts. I want to get the motor/trans bolted in so I can start fabing I/C and Exhaust.
Also I need bolt for a auto t-case.
Anyone know where there's one hiding in a junkyard? Auto AWD
Old 04-07-2010   #6
fount the front roll stop mount
also have t.converter bolts
Old 04-07-2010   #7
dragonforce
You can have my 6 bolt flex plate.
dragonforce is offline   Reply With Quote
Old 04-08-2010   #8
s1ngletracker
s1ngletracker's Avatar
Drives: A BMW
I have 1-3, what are they worth to you?
Style's automotive engineer
