Old 04-03-2010   #1
blackrosenova400
blackrosenova400's Avatar
To who may have blown a tranny or scared they may blow one
I dont know why any of the respected tranny rebuilders never tell anyone this, maybe for job security.........
It is very important to replace motor mounts when making good power, especially with our 15+ year older cars that have worn mounts.
It is a good idea to replace them with stiffer mounts as normal mounts or worn out mounts will cause engine shake, and when it shakes it releases and applies engine load on and off fast. This can cause gear chatter with high load! It like taking an air impact to your gears, not cool.
Just thought id share this to help our commnity a bit as it seems these tranny's can get the best of us!
20g Mafia
Old 04-03-2010   #2
Jungy
Jungy's Avatar
Re: To who may have blown a tranny or scared they may blow one
Good point. The front and rear mounts are the problematic mounts when it comes to the unnecessary stress placed on the trans that you are mentioning more so than the left and right mounts.
Old 04-03-2010   #3
123abc
wants to be sideways...
123abc's Avatar
Drives: Loud cars
Agreed. Even for clutch engagement and normal driving, solid poly mounts help so much. I use to get wheel hop with just the two side mounts change out. As soon as I switched the front and rear mounts, absolutely zero wheel hop. It either hooked up or spun the tires, but it was without shaking or violence.
Originally Posted by Matt D.
Originally Posted by 93GSX5SD
Old 04-03-2010   #4
I am a fan of solid torsion mounts on high HP cars. Polys are good for the more DD cars, but chrome moly mounts are easy to make and install for the weekend warriors.
Old 04-03-2010   #5
I personally love the mounts john made me for the front and rear of my car. Solid, plated metal, no poly bullshit here. And, it's not that bad for a DD either. (yes, DD over the summer months, since I know someone will be a wise-ass and tell me it's not a DD)
Old 04-03-2010   #6
It's not a DD
Old 04-03-2010   #7
See?
Old 04-03-2010   #8
^How are poly mounts so bullshitty?
Old 04-03-2010   #9
Another thing is a lot of people forget about the 12mm bolt on the back of the trans to the block.
Old 04-03-2010   #10
They aren't, just giving people crap.
Old 04-03-2010   #11
CarPsyco84
CarPsyco84's Avatar
Swifty likes to rattle all the bolts loose on his car...
-When in doubt, Moar RPM.
Old 04-03-2010   #12
^How do you do that when it never runs?
Old 04-03-2010   #13
santa
Boost Spike
santa's Avatar
I like this! Good luck with solid motor mounts.... There is a reason why they never put solid mounts in car's besides the vibration
Old 04-04-2010   #14
CarPsyco84
CarPsyco84's Avatar
Well that's why they all were advocating the solid mounts.
Old 04-04-2010   #15
At the same time too stiff of mounts can cause faster wear on parts. The engine needs to flex sometimes to make it easier on the drivetrain and other components. Too stiff of mounts like solid mounts can cause issues. The car i have now is running full poly mounts, i am not sure i would ever do full solid mounts unless it is a race car where i need every ounce of power to go directly to the drivetrain. However, i do agree with you in the respect that bad mounts especially front and rear can be horrible on the drivetrain and other components more than mounts that are too stiff.
Old 04-06-2010   #16
turboimports
turboimports's Avatar
Drives: DSM and Mitsu history
I have poly inserts in mine. Some vibration from stock of course, but holding up great.
Old 04-06-2010   #17
mdost03
Sonic Champion!
Drives: VA STI
Using solid mounts here, no issues and I DD the car. NEED these mounts to be able to floor it in 1st-2nd gear.
Old 04-06-2010   #18
I had all 4 poly mounts on my DSM and it was stupid. On my Evo I have just a poly front motor mount and its perfect for a street car. Nice crisp shifts with very minimal vibrations at idle.
Old 04-06-2010   #19
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
I am poor so I use the 3M Gooped stockers
Old 04-06-2010   #20
Every time i have used full poly mounts i have never had issues with vibrations. Lucky i guess. I have heard a lot depends on the balace of the motor, Similar to when you remove your balance shafts.
