Old 04-08-2010   #1
rocket2g
Drives: 2g
1994 eagle talon tsi AWD part out
I have a 5 speed manual 1994 Eagle Talon Tsi AWD turbo with the 4G63 motor. It's a 7 bolt motor with the 4 bolt rear end. I have a Super clean 1992 Eclipse GS non turbo 5 speed with super clean body with a 6 bolt for rebuild if you needed one of those too. 94' has a green body I'd say about average for the roadworthy DSM's you'll see on the road. It does have a small amount of surface rust at spots along the rear wheel wells. It was backed into at some point before I got it not serious at all just shows it's age being an afordable turbo tuner car. I bought it with 163K and now it's in my garage with 165K on it. Bought it from my cousin who said the tranny was rebuilt at like 125K. When I bought it it was in need of some parts. All of these parts and labor have under 2,000 miles on everything! Most just a couple hundred or less. All bought brand new from Modern Automotive and have all the reciepts in hand to show it. Can't afford to have 2 full blown tuner cars so I'm keeping the twin turbo. I'm looking to sell everything together I've got about $12000 invested so no lowballers. I would consider a partial trade or trade but it must be drivable. All parts can easily be swapped to a 2G Eclipse. Here's a list of the mods/repairs upgrades etc... since I've owned the car.
The Good
Stock replacement front bumper from 1G talon painted 2 tone, green with gunmetal bottom. Looks really decent.
Aftermarket Foglights fit nicely into bumper $50
New Alternator Acc. Belt $20 $85lbr
4 new 205/55/16 tires on stock rims painted black $660
Tie Rod End and Replacement $55
Front drivers side axel and replacement $75
Clutchmasters FX500 Dual Friction stage 5 clutch 4-Puck disc 200-400% holding capacity (whole clutch kit) and replacement $900 $475ctch $425lbr
Fidanza 11LB Aluminum L/W Flywheel a loss of 7lbs over stock which puts 18.9HP back to the wheels. Each pound is good for 2.7WHP $200
K-Sport Kontrol Pro Fully Adjustable Coilover Kit 1G Adjustable 36 way $830
Apex'i AFC-II Air/ fuel ratio controller silver and blue works great. $400
Maniac Electric Motors 150 Amp high output alternator $215
All Aluminum 2G Radiator $150
Gates Coolant Hoses 1G Both upper and lower radiator hoses (Blue) $50
MSD 8.5mm Spark Plug Wires (Red) $92
Mishimoto 14" Electric Fan 12V with on/off switch next to shifter can be turned on with the car or whenever disireable $97
MHI Evo III Big 16g Turbocharger $550
Pun. Racing SS Tubular O2 Housing/Mits flange/external dump Into atmosphere (really opens up around 4000RPM) $220
Slowboy Racing SS J-Pipe with Gasket $95
O2 Gasket/7cm Turbine Inlet Gasket/O2 housing to DP gasket/2 Throttle body gaskets $55
Fuel Injector Clinic 850cc fuel injectors $275
Hallman Evolution RX Manual Boost Controller Black 72" length(In cock pit on left side of steering wheel for instant boost) $170
Walbro 255lph fuel pump $95
E85 conversion 105+ octane gives you 30-40 more HP in turbo applications meaning more powerful boost! Cheaper and more power than gas.
Mass Airflow Translator 1G DSM $200
GM 3.5" MAF Absolutely huge $100
Punishment Racing Tubular Exhaust Manifold w/heat wrap $500 Wrap another $50
JM Fabrications Universal Polished Oil Catch Can with breather filter $65 (keeps the oil out of the engine bay and contained)
Prothane Black Motor Mounts $77
Bullseye Power 3" Intake Pipe $125 Filter and tubing $60 (Adjustable tube allows filter to be located in the front bumper wheel well etc...)
Goodridge SS Brake, Oil Feed, Turbo Oil Return Line and Clutch Line $55
Innovative Motorsports Wideband O2 kit DB-Blue kit. Blue LED display guage in dash and additional O2 sensor into downpipe. $275
Buscher Racing 3" Downpipe with dual O2 Bungs and heat wrapped $255
Aftermarket 3" straight pipe (cat delete) $100
Apex'i 3" Catback Exhaust with cannister Muffler $600
Black Thermal Coated 3" intercooler piping everywhere $200+ $75 custom fabrication BOV
Greddy RS Blow Off Valve. Silver and Purple/reddish color. $150 Into atmosphere HUGE SOUND OOOOSH every gear change everyone notices!
Autometer Dual 1G guage pod Black with Water Temp and Boost Pressure guages installed $150
Autometer Oil Pressure guage installed in the odometer $60
8 Piece Brass Stiff Shifter Bushings Stiffens and makes it a short throw shifter $30
2 Piece Brass Stiff Bushings Kit for the unerhood shift linkage $30
2G throttle body elbow $20
NGK #5 cold plugs gapped to .28" from.32" shorter distance for quicker spark $20
Optima red top battery $160
Also more Vibrant Couplers and Tbolt clamps than I can count easily $300 or more many are $20-$30 each.
Im sure there's some more parts I left out but thats all I can think of at this moment.
Here's what it needs:
I have aftermarket upper control arms new in box $200 that need to be installed quoted at $200 labor.
The fan switch needs to be more securely wired it can loose contact randomly.
Wideband O2 needs to be finished being hooked up. Almost finished Guage is installed and O2 is in downpipe just didn't want to do it wrong.
And it would then need a tune. Like I said I went to Modern Auto for all my parts and consulted them before any purchases made each time. They say with a tune and the parts I'd be in the 400-425WHP range. High to mid 11's in the 1/4.
Cash talks but it better be enough for me to hear what is saying otherwise I don't understand that language either I'm not giving it away when I can go grab a 2G for 2000 and swap all the parts over and run 11's. $5000+ on trade value or $4000 cash money.
Have tons of extra parts, air filters, air intakes, turbo MAS, Exhaust manifolds, downpipes, couplers, clamps etc....
763-647-4164
*call perfer/text*
prices are what they cost me, not what im selling them for!
pictures---- http://minneapolis.craigslist.org/hn...653606828.html
******************will trade for 3000gt vr4 or stealth tt in decent running condition*********************
rocket2g is offline   Reply With Quote
