Old 04-20-2010   #1
Gravy
Who's this guy?
BOV Location
I could have sworn that placing the BOV as close to the throttle body would reduce a surge of air each time you let off the gas. But i seem to have trouble finding a confirming answer. Wonder if anyone knows the answer, or could explain why the location doesn't matter.
Put the car back together, but the BOV is pre FMIC and my first test and rev blew 2 vacuum lines off the car. Not sure if it was on weak, or my memory was correct. The two lines were the blown off was the boost gauge and BOV line.
Gravy
Old 04-20-2010   #2
Re: BOV Location
Theoretically the BOV should be as near to the TB as possible.
Old 04-20-2010   #3
Andrew7dg
Built it from scratch!
Andrew7dg's Avatar
Drives: Currently Mitsu-less
Re: BOV Location
+1
From the books that I have read
Old 04-20-2010   #4
Gravy
Who's this guy?
Re: BOV Location
The reasons i asked is because i've run into different forums that say to put it as close to the turbo as possible, to allow the new air on the system's pressure to bleed off. Most of the people who say that are also running a closed loop, so the route to the MAS is the shortest it can be.
I have also seen many people state that you put it as close to the FMIC on the cold side so that the air doesn't back flow or "Surge" back though the core. It acts as sort of a slow speed break on the air, so anything building up will exit and the air pre fmic will exit as soon as it enters the pipe system.
And, have seen as many people say as close to the throttle body, but never give a reason that made sense. It should, in theory work like the second mentioned reason, but at the end of the system preventing the air to have to travel back much at all.
Going to re-configure the bov location but it seems to not be working the way it should on the hot side of the piping.
