Old 04-22-2004   #1
jd1828
Send a message via AIM to jd1828
ever since i did the crankcase and pcv vent mod the engine has slowly started to leak oil from the valve cover and a lot from the oil pan. this is on a engine with all new gaskets that didnt leak a drop of oil before the pcv mod.
i remember i was talking to someone on here that said they used a vacuum pump on their crankcase. where can i get an electric pump? all i can find is the belt driven ones. how much oil does the pump pull out of the crankcase?
jd1828 is offline   Reply With Quote
