Old 05-13-2010   #1
adidasdudegst
adidasdudegst's Avatar
Drives: 03 TB EVO
Clutch, Slave, Master Or Tranny?
Ok, So i have looked at many of threads now discussing this problem, and haven't really seen to many successes at the end of the thread, at finding out the cause of the issue and fix to the issue.
I have a 99 GST FWD. Just had the motor pulled, did the timing belt etc. Got a brand new RPS Max Pressure 2500lb clutch, with a fidanza flywheel. Brand new OEM fork, pivot ball, boot, throwout bearing and clip. I also just put in a slave cylinder extension rod, figuring that would fix the problem (figured it just wasn't disengaging all the way).
The issue is the tranny does not want to go into any gear hardly at all. It's almost as if it's not disengaging all the way. It will go into gear with force, and sometimes the clutch pedal has to be pushed down a few times. With the car running, if I sit and press on the pedal a few times fast it seems that a few of the times going into gear it will get easier, other times not. The slave cylinder was brand new at the end of last year. I plan on replacing the master, and properly adjusting it, but i'm trying to figure out if its worth taking the extra time to do that, or if I have to pull the whole dang tranny out again. When you do get it into gear, with the clutch pedal in/clutch disengaged, it will start creeping ahead, and other times like if I were to repeditively press the pedal in 5 times b4 shifting into gear, it will stay put for a little bit. I wouldn't think it would be the master cylinder, because when the clutch pedal is pressed in with the extension rod now installed, you can see the fork moving the full sweep.
Any ideas? this is just killing me after spending all this time on the car, and everything is finally back together, minor engine kinks are worked out, and now that it's able to roll, it doesnt want to to easily haha
