Old 05-16-2010   #1
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
2004 Volvo S60R 66,500 miles 6 speed manual
$12,000 OBO
Black Sapphire Metallic
66,500 miles
6 Speed
All Maintenance up to date
Located in Bloomington, MN
My name is Colin
My number is 651-260-5264
This car is an absolute thrill to drive. It is the greatest car I have driven in the winter. It currently has snow tires on it and they are on their 2nd season.
I has a couple of blemishes on it including a missing side marker because some idiots dont know how to back out of parking spots. Car is washed at least once a week in the winter and waxed twice a year. Oil is changed every 3000-3500 with Castrol Synthetic. It just had its 60K mile tune up which included rotating and balancing tires, All fluids flushed and topped off, along with all the filters being replaced. I recently had the transmission out last year to replace a broken slave cylinder and checked the spline shaft on the angle gear and it looked great!
This car has factory sound with 13 speakers and sounds amazing played with any music! It has Nav, Cold weather package including rain sensing wipers and heated seats, 18 inch rims, Car is Fully loaded minus the volvo child seat. Thats the only factory option it didnt come with, oh well.
Car has stiffer motor mounts, and lower transmission mount. The brakes were recently replaced around 10,000 miles ago. Stops like a champ.
Call or email if interested. Car has clean Title, I will Pm mod with my VIN if we still need to do that?
-Colin
Things needed still:
Car needs new strut tower mounts which I have an appointment to get new ones installed next weds the 19th.
Not sure what is wrong with the steering wheel but it is off center, it still drives straight and has a good alignment too.
Crack in the windshield.
Tires are still winter tires, I have summer tires but they are worn pretty good.
Car has a dent in the drivers side door.
Nice extras:
Comes with brand new 3 inch down pipe.
Comes with 2 extra 18 inch PEG rims. same as a stock R so you would have a total of 6 including the ones on the car.
Old 05-16-2010   #2
Re: 2004 Volvo S60R 66,500 miles 6 speed manual
Very nice, I miss mine sometimes.
Old 05-16-2010   #3
Price?
Old 05-16-2010   #4
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
12000 OBO
-Colin
Old 05-16-2010   #5
viridionplague
reason for selling?
Old 05-17-2010   #6
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Going back to school in the fall and need to free up some funding.
-Colin
Old 05-17-2010   #7
That's a hell of a price! I sold mine for $11,750 with 20k more miles and an auto, most people that know what the R is want the 6-speed.
Old 05-17-2010   #8
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Yeah I figured I would be getting more interest.
Ugh, oh well its for sale. If an offer comes along I like I will take it!
-Colin
Old 05-17-2010   #9
Some specs on the car?
Old 05-17-2010   #10
I found out today that the guy that bought mine totalled it, I'm sure he'll be calling you soon.
Old 05-17-2010   #11
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Description S60 R
2.5 Liter, 5-Cylinder, Continously Variable Valve Timing DOHC, Turbo with Twin Intercoolers
Configuration Transverse
Displacement (cu.-in.) 2,521
Compression Ratio 8.5:1
Maximum Boost Pressure 1.0 bar
Horsepower (SAE net) 300 @ 5,500 rpm
Torque (ft. / lbs. SAE net) (6-speed close-ratio manual transmission) 295 @ 1,950-5,250 rpm
Max Engine Speed 6,500 rpm
Fuel, Rec. Octane Premium
Description S60 R
Anti-Lock Braking System with EBD and EBA
4-Piston Brembro Brakes with Aluminum Calipers
Disc Diameter (Front/Rear) 13 / 13 in
Wheelbase 107 in.
Height 55.0 in.
Length 181.3 in
Width 71.0 in.
Front Track 61.3 in.
Rear Track 60.7 in.
Towing Capacity 3,300 lbs.
Cargo Capacity (Rear Seat Up / Folded) -
Fuel Tank Capacity 18.5 U.S. Gallons
Trunk Capacity 13.9 cu.ft.
Curb Weight 3,571 lbs.
Weight Distribution, Front / Rear 55 / 45%
8" x 18" - "Pegusus" 5-Spoke Alloy Wheels with 235 / 40ZR-18 Tires, Y-Speed Rated
Suspension Front: MacPherson Struts with Asymmetrically Mounted Coil Springs, Electonically Controlled Hydraulic Shocks, 23.5 mm Stabalizer Bar
Suspension Rear: Multilink Independent Rear Suspension with Coil Springs, Electronically Controlled Hydraulic Shocks, 20 mm Stabalizer Bar
Six-Speed Close-Ratio Manual STD
First Gear 3.38 : 1
Second Gear 2.05 : 1
Third Gear 1.43 : 1
Fourth Gear 1.09 : 1
Fifth Gear 0.87 : 1
Sixth Gear 0.70 : 1
Final - Drive Ratio 3.77 : 1
Electroincally controlled all-wheel-drive
Four-C (Continuously Controlled Chassis Concept) System with Driver-Selectable Settings: Comfort, Sport, Advanced Sport
Top Speed (Electronically Controlled) 155 mph
Manual Acceleration (0-60 mph) estimated 5.4 sec.
Stopping Distance (from 62 mph) 118 ft.
Manual Trans City 18
Manual Trans Highway 25
-Colin
