Old 04-22-2004   #1
DSM97RS
Send a message via AIM to DSM97RS
i have had my power steering/ac belt come off a few times and didnt know what was wrong, finally i brought it into a shop and was told that i needed a new idler. Is this what i need? http://cgi.ebay.com/ebaymotors/ws/eBayISAP...sspagename=WD1V
if not, what do i need to make sure these belts dont keep getting thrown off?
DSM97RS is offline   Reply With Quote
Old 04-22-2004   #2
jd1828
Send a message via AIM to jd1828
no, you car only uses an idler for the timing belt. your should check your crank pulley to make sure it not comming apart.
jd1828 is offline   Reply With Quote
Old 04-22-2004   #3
DSM97RS
thats why i asked here cause i was confused on why they told me i needed an idler when my accessory belt came off. ive already replaced the tensioner and the tension is fine, what else could cause it?
Old 04-22-2004   #4
unreal808
Mr. Me Too
unreal808's Avatar
Drives: Suzuki GSXR
check your harmonic balancer /crank pully. the thing will fall apart and buck belts
Take her to the limit!
Old 04-22-2004   #5
Jacek
Captain J-Sack
whats the overall condition of the grooves for the pulleys? any dents in them?
Old 04-23-2004   #6
DSM97RS
ill check the pulleys tomorrow, im pretty sure they are in good shape still tho. What should i be looking for on the crank to tell if thats the problem? thx for the help guys, i dont feel like spending 350 for them to "fix" the problem
Old 04-23-2004   #7
JasonR
serpentine belt or ribbed v for power steering. check it. Take a flash light and check crankcase pulley or also known as harmonic balancer which also holds accessory belts. Probably the tension needs to be adjusted so it is tight enough. loosen adjusting bolt. Once desired tension is met, tighten adjusting bolt and check again. Need correct tools. There are a few people or shops who I would let touch my car if I had too after I have owned and been involved with owning a fast eclipse. Why I do all work. I cannot believe they said replace idler. There is tensioner pulley and idle pulley which timing belt goes around. They must be on LCD OR SMOKIN POT.
Old 04-23-2004   #8
DSM97RS
i know i need to check the crank pulley, lol, i was asking what i was looking for on it to tell if i need to fix it... and i think you mean LSD
Old 04-23-2004   #9
JasonR
Sorry about the lsd thing. Its just the fact that the shop has no idea whats going on. I have a harmonic balancer with bad corners. They were chiped and the groves were rusted badely. This caused a twist in the belt for power steering. It never came off, but that is because I replaced it immediately. So if you see chip markes, bad rust or a warped or bent pulley with bad corners, MAY BE THE DIRECT CAUSE.
Old 04-23-2004   #10
DSM97RS
well if this is what they mean by "idler" would i just be better off buying an underdrive pulley? also what part number should i look for when i go to get a belt, anyone?
Old 04-23-2004   #11
Don't get an underdrive. It's an RS, leave it stock! Also the underdrives don't dampen the vibration in the crank, so they can lead to premature failure of the engine. That thing probably isn't putting out enough HP to worry about it, but I still would stick with stock.
Old 04-23-2004   #12
DSM97RS
well i also have 2 tvs, an 90w computer and some other stuff running so i didnt think it would be a good idea anyways, haha. any idea on that belt #, where would i get a new crank pulley also
Old 04-23-2004   #13
JasonR
Stock harmonic balancer, dont get aftermarket. Someone else mentioned this. Just give dealership model and yr of your vehicle and they should have a belt in stock. Mabey not the balancer. Say everything twice with them and confirm with them. Thay have unfortunately made mistakes.
Old 04-26-2004   #14
2003eclipse
Slower than a rusty Honda
2003eclipse's Avatar
Mr. Raced always used the throw belts on his 2g it would only buck under High R's when he'd tach it up to about 6,000, Simple fix dont tach it up that high.
I LIKE TURTLES
Old 04-28-2004   #15
v8klla
v8klla's Avatar
Mike told me something about putting one of the pulleys on backwards on the water pump, granted this was on a 4g63 but I could see how you could put the pulley on backwards and not realize it. Apparently one side of the pulley has a wide tapered end and that is known to throw belts if installed backwards. Worth checking into...
Chris
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 04-29-2004   #16
CDeutsch
CDeutsch's Avatar
Yeah on the 4G63 it's very easy to put the water pulley on backwards (not sure about the NA). I've done it and it threw the belt. Also make sure the Alternator pulley is not wearing. Use a big flat ruler or something to make sure the alt belt is in line with all the pulleys. Or just eyeball it really good. Something has to be out of line, or one of the pulleys has to be bad.
06 Evo IX RS
99 Miata
Old 04-30-2004   #18
Mr Raced
Yeah DSM97RS, i had a 95 Gs and it would throw a belt every now and then. I talked to a bunch of guys with the same type of car and they said it is a common thing when revving high and especially when you launch or spin the tires. Just try not to rev it so high on launches, and dont hold high rpm's for very long. :secret:
Old 05-07-2004   #19
DSM97RS
awesome, im glad i didnt spend the money to have them put in a new pulley. im guessing i can pickup some belts forom autozone or stores like that, anyone know the part number i need tho? thanks
