Old 05-30-2010   #1
C89ZX7R
C89ZX7R's Avatar
Drives: 87 and 89 Chrysler Conquest
Rebuilding the 87 Conquest TSI
Picked up a 87 Atlantic Blue quest two days ago around midnight. Its just a roller. Has dings which looks to be from hail on the roof and the hood. Had some squirrels living in it, found some acorns in the glovebox and under the wiper cowl. Plus the carpet had what looked to be squirrel shite all over it. The following day I started to remove the front end for small rust repair.
Fixed some rust and used rubber undercoating in the fender wells and on the frame rails. Then sprayed the front section and engine bay rails down with black rustoleum paint.
Edit "Friday April 29th 2011" Mod List Below
Rebuilt Bottom End, Stedebani 95A Motor Mounts, Balance Shaft Elimination, Jet Valve Elimination, Throttle Body Rebuild, Krank Vents, MK1 Egr Block Off, GM Delphi Injectors, GM 110 Amp Alternator, Alternator Ground Strap, Transmission to Firewall Ground Strap, Dual Alternator Charging Harness, Optima Red Top, 1G Maf, TD05-12A, KDM Turbo Small Discharge Pipe, KDM Turbo Inlet Pipe, TEP Ovcp w/ Turbo-Xs Type H Bov, 14.5psi Boost Pill, 2.5" Catless Turbo Back, Stock Twin Tip Muffler, 83 Starion 2 Piece Crank Pulley, Rodded Stock Radiator, Accel Yellow Coil, Accel 8.8 Wires, Fram Oil Filter, Rotella T6 Full Synthetic, New Coolant Temp Switch, New Master Cylinder/Water Pump, A/C Delete, Abs Delete, Star-Orion Abs Line, Steel Braided Turbo Oil Feed Line, Charcoal Canister Delete, Anti-Roll Over Valve, 89 Ecu, 89 Airdam, 89 Rear Starion Shoulder Belts, 89 Rear Seats, 89 Hvac Panel, Grant Steering Wheel, Stedebani Short Shifter, Eibach Rear Lowering Springs, Suspension Tech Front Lowering Springs, Shp 8 Way Front Struts, Kyb Gr2 Rear Struts, 90/100 Watt Relayed Headlights Harness, H4 Headlight Housings, Silver Star H4's, 55 Watt Foglight Bulbs, Foglight Mod, Resprayed Flat Black.
Motor Is Tight, Sounds Unbelievably Badass, Intimidates Slow Hondas Instantly
C89ZX7R is offline   Reply With Quote
