Old 05-31-2010   #1
95talonracer
Finally Tuned...
95talonracer's Avatar
Drives: Spyder GSX
FS 1g and 2g parts stock and aftermarket UPDATED
I have a bunch of 1g and 2g parts for sale and here is just a small portion of what I have. If there is anything else you need just PM me and ill let you know if I have it. PM me if interested in anything. Everything is B/O
7 bolt arp head studs
2g map sensor
Stock quality plug wires
2g drivers motor mount (needs poly bushing pressed in but not included)
2g grey trunk lid
1g coil (missing plug)
2g coil (missing plug)
intrepid coils
resistor box for injectors
1g Non turbo throttle body w/sensors
8-10" -4 AN stainless line
2g fwd fuel sending unit
1g green top cas with pigtail
-10 AN adapter for turbo oil return
2g awd fuel sending unit perfect shape
2g awd fuel sending unit missing fuel supply fitting on outside of unit (good for custom dual pump system)
1g thermostat housing with all sensors bead blasted and looks near new
oil feed adapter for -4 AN line (adapts from the oil filter housing to run -4 line)
2g tps
2g trans mount bracket (bolts to trans and is black)
1g intercooler
stock 2g exhaust manifold
ported 2g exhaust manifold with egt sensor installed but can easily be blocked
2 black top 450 injectors (one needs cap on spray tip)
41-44 mm Tial 4 bolt wastegate with fire ring blue in color
comp 101100 cams in great shape
front driver 2g dual piston caliper (have passenger but is apart)
92-96 manual transfer case
2g shifter assembly
2g shifter cables
2g top timing cover
2g lower timing cover
stock 2g exhaust manifold cover
2g stock intake manifold
stock 2g t25 turbo
stock 2g 02 housing
PM me if you are interested in any of those parts or are looking for anything else.
Amsoil Dealer
Old 05-31-2010   #2
cudvig
Rainbow Boy
cudvig's Avatar
Drives: 96 Civic HX
Re: FS 1g and 2g parts stock and aftermarket UPDATED
How much for cams and wastegate?
-Colin
Old 05-31-2010   #3
viridionplague
is the non turbo throttle body fitted with seals for boost?
Old 06-03-2010   #4
95talonracer
Finally Tuned...
Drives: Spyder GSX
PM Sent
Amsoil Dealer
