Old 06-04-2010   #1
SpyderGSX07
SpyderGSX07's Avatar
Drives: 97 GSX Spyder/99 Chev S-10
FWD Auto To AWD Manual
I've have a 97 automatic mitsu eclipse spyder that i am converting into a AWD Manual (Drivetrainwise). I am using a 95 gsx donor car for all of the necessary parts. The problem i am having is with the safety neutral switch. How can i make it work with the clutch petal. What does that switch see? Does it see a constant 5 volts? Does it have to be grounded to start? Also, I did take the cable and connectors out all the way to the ignition thinking i wasn't going to need it because it was going to be a stick. Well i guess i need it. It would be great if you could help me out! Thanks For Your Time.
SpyderGSX07 is offline   Reply With Quote
