Old 06-09-2010   #1
Torque for Rod Caps with ARPs
Ok, so i wanted to get an opinion on this. I havent dropped the pan yet but i have the feeling the bastard loosened again. or more-so, in the case that it has i would like to know what you all think.
The rods are Manley I Beam baller ass rods, they come with ARP 2000 rod bolts for the caps. Im using the moly lube on the bolts. When i built the motor i torqued it to the factory setting. Everything should have been perfect. I believe i was told it was 38 ft lbs. (if its not dont flame me, it was a while ago that i actually torqued them).
If the case is that the bolts came loose again, should i look into torquing it higher? I know the torque wrench is accurate, its a brand spanking new craftsman torque wrench.
Anyways, What do you guys think, Is this like the ARP Headstuds where i should be torqueing much higher than stock, or what?
Thanks in advance,
Tom
