Old 06-14-2010   #1
2g Monson
2g Monson's Avatar
Drives: 1995 Eclipse GST
7 bolt parts on a 6 bolt?
When putting a 6 bolt block into a 2g am I supposed to use the accessories off the 6 bolt or can I use parts off the 7 bolt block. It is going to have the 2g head.
Can I use the 7 bolt aluminum cover (left) or do I have to use the 6 bolt (right)
Im wondering due to the crank sensor on the 2g that isn't on the 1g and the and since I'm using the 2g head it wont have the crank angle sensor (correct me if I'm wrong)
Also which plastic cover would I use?
Most mounting holes appear to be in the same location, but this is a first for me so I'm still a little lost.
I found this link but it doesn't seem to mention using a 2g head http://www.dsmtalk.com/forums/showthread.php?p=2273646
2g Monson is offline   Reply With Quote
