Old 06-24-2010   #1
maperformance
Drives: EVO
Send a message via AIM to maperformance
MAPerformance Drag Evo / 916whp 604wtq / Stock ECU
It's been a long journey, but I believe we've reclaimed the highest horsepower stock ECU record We don't expect this to last long as we've got some stiff competition out there, but this was only 37psi and although its cliche, there's a lot left in it We'll be out at BIR this weekend to see what she can do (albeit on stock suspension and street tires for now), yet another reason to attend our Proving Grounds event!
Build Details
MAP Stage 2 2.4L Shortblock
- OEM 100mm Crankshaft
- Wiseco HD Pistons
- ACL Race Bearings
- MAP Spec Howard's Rods
MAP Stage 5 Cylinder Head
GSC S3 Camshafts
Fidanza Cam Gears
Precision Turbo Billet 76mm Ball Bearing Turbocharger
Speed Density with AEM 5 Bar (Special thanks to Scheides for all of your help!)
Sparktech Coil on Plug
AEM CDI Ignition Box
ETS 5" Front Mount Intercooler
Fuel Injector Clinic 2150cc Injectors (E98 Fuel)
Magnus V5 Cast Intake Manifold & Fuel Rail
OEM replacement parts supplied by mitsubishiparts.net
QuarterMaster Twin Plate Clutch (2010 Revised Version)
Torque Solution Motor Mounts
Mishimoto Aluminum Radiator
Turbosmart Raceport BOV / 45mm Wastegates / eBoost2 / AFPR
Stock ECU Developers / Innovators
As always we can't say enough about how thankful we are to the stock ECU gurus that made this a possibility. If I try to name all of you I will most certainly leave someone out unintentionally, so I hope that addressing the group as a whole will sufficiently convey our gratitude If ever there is anything we can do to further advance the capabilities of the stock ECU please don't hesitate to let us know!
Click the image below for a larger view!
Thank you to our sponsors, this wouldn't be possible without you!
maperformance is offline   Reply With Quote
Old 06-24-2010   #2
Re: MAPerformance Drag Evo / 916whp 604wtq / Stock ECU
Congrats! That thing is laggy, but with traction in mind, it may be a good thing for you. Do whatever you have to to keep in boost between gears and you should run some good times. Good luck.
Old 06-24-2010   #3
Constant_Project21
Constant_Project21's Avatar
Drives: E36
Damn, congrats guys!
Old 06-24-2010   #4
92pearltt
Drives: 91 fwd stealth tt/ 99 SL
Great numbers, but whats the deal with the lack of torque?
1994 RT/TT - Stockish for now ;)
1991 RT FWD TT - Race car work in progress
http://i110.photobucket.com/albums/n..._3110121_o.jpg
92pearltt is offline   Reply With Quote
Old 06-24-2010   #5
munchgsx
munchgsx's Avatar
Drives: 2004 Corvette M6 F45
It's a big turbo 4cly. Torque is not an option. Plus that is really good torque for the set-up.
Old 06-24-2010   #6
Congrats on getting it all figured out and a good turbo on there. That thing should really move out.
Torque is for diesels... It sure isn't needed for a fast drag car and often you don't want it to avoid breaking parts.
Speedfreak: That's not laggy. That would be a quick spooling turbo on a Honda.
Old 06-24-2010   #7
Murlo26
Murlo26's Avatar
Drives: 17 Honda Accord
Torque looks solid I think...lag it a bit rough, that's a big ass turbo.
Old 06-24-2010   #8
v8klla
v8klla's Avatar
Power...check. Practicality...not a chance
Chris Carey, President
Modern Automotive Performance
P: 763-545-3800
E: chris@maperformance.com
Old 06-24-2010   #9
^hahahaha.
Congrats on getting this figured out. I can't wait to see it on SATURDAY!!!
So what times do u need to be competitive on the record holding end of things?
Old 06-24-2010   #10
Very impressive!
Old 06-24-2010   #11
Monstrous!
Old 06-24-2010   #12
Woohoo! Congrats guys! Glad this thing got sorted, I CANNOT WAIT to see this thing make some rips down the track!
Def curious to see how tephra's implementation of NLTS works on this thing!
Old 06-25-2010   #13
blackrosenova400
blackrosenova400's Avatar
Out of curiosity, what is the base fuel pressure and injector duty cycles at with those power levels?
20g Mafia
Old 06-25-2010   #14
Thats nutty! Cant wait to see times!
Old 06-25-2010   #15
v8klla
v8klla's Avatar
I believe 43.5psi base, but no idea on the IDC as it wasn't really a concern for us with the 2150s
P: 763-545-3800
Old 06-25-2010   #16
Sweet!!
Old 06-25-2010   #17
If the base is at 43.5, they might max in the high 900s on E98, unless you run it kinda lean. But with injectors that big, just bumping the base to 50psi or running it at 12.5 versus 12 can be a lot more power range. I was at 76% on E85 with the ID2000s(same injector as the FIC 2150), 50psi base fuel pressure on an Evo I did last year making about 837awhp Dynojet numbers. I told English Racing the base fuel pressure and duty cycle and he guessed the power it made within 10awhp.
Old 06-25-2010   #18
TalonFiero
moonshine power
TalonFiero's Avatar
Drives: 08 Saab 9-7x Aero
Nice work Kyle and gang, really impressed with the power and lower boost.
Old 06-25-2010   #19
The 37psi is very impressive. That intake manifold or head or cams or all of them are doing something right.
Old 06-25-2010   #20
Great power for the boost, good luck at the track.
