Old 07-07-2010   #1
FS: 1G Intake Heat barrier Gasket - $35/obo
Brand new never used.
A special high temperature insulating gasket which replaces the stock intake gasket. This and bypassing several heat sources significantly reduces the transfer of heat from the head to the intake and incoming air giving you up to 5% more power.
Turbocharged cars often use an aluminum intercooler to cool the air compressed by the turbo. The intake manifold is also made of aluminum but because it is heated by the head from combustion and coolant, works in reverse to an intercooler by heating the intake air by as much as 50° C and only takes 2secs to install with intake manifold off.
$35/obo
