Old 07-21-2010   #1
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
Drives: Cyborg from Japan
Keep blowing MPI fuse..
Well recently my car started blowing the MPI fuse.. It happens about every 2-3 days. Also one thing I noticed which I think might be contributing to it is one of my injectors (1600's) Keeps getting stuck closed every once in awhile while I'm cruising on the freeway and it'll misfire on and off for a bit. But then it will clear up and be fine again. Would this cause the MPI fuse to blow? Or would it most likely be a wire shorting out? The fuse started blowing more often as the misfiring kept getting worse. I'll more then likely have the injectors sent out to get cleaned and flow tested.
-1990 Mitsubishi Cyborg 4WD-
Old 07-21-2010   #2
twack
It was a auto get over it
twack's Avatar
Re: Keep blowing MPI fuse..
this happened to me and it was a wire grounding out. I went through abot $20 in fuses before i found where it was grounding. With me it was a wire grounding out from my wire tuck.
Old 07-21-2010   #3
4g63tcrazy
is Nashty
4g63tcrazy's Avatar
That's what I figured.. Plus I just re-did my whole wiring harness this winter. I guess while I pull the tranny I'll have to pull the harness as well.
Old 07-21-2010   #4
twack
twack's Avatar
ya it sounds like a wire somewhere that either has a small bare spot or an open end that once in awhile will move with the car and short out.
Old 07-21-2010   #5
1QUICK4
Crash Course Racing
1QUICK4's Avatar
Drives: in circles
Wire shorted to ground or the problem I had with my Galant was the MFI relay was bad/shorting to the case
Old 07-21-2010   #6
Last time i saw this it was a grounding issue also.
Old 07-21-2010   #7
I have a spare relay that you could borrow for awhile, just to see if that is the cause.
