Old 08-10-2010   #1
DSM_brother2
Drives: to the shop
car wont run!
so my car ran 2 weeks ago just fine, needed a tune. but the oil pressure was low so i figured lets do the oil pump.
i then did the oil pump and put the car back together, and proceeded to start it.
it didnt want to fire, so i checked the timing and it was off a tooth. then i fixed that. i then started the car and it fired right up, i tryed to rev it and it wouldnt rev, all it did was build boost.
i asked around and most said timing, checked it 3 times and its right on. also the compression numbers are 145 across. others said boost leak, so i started to check around. i sealed the throttle body stuff up and you can just hear air leaking out as fast as you can fill it, but i cant find out where.
does anyone have any ideas?
93 talon tsi/ 6 bolt swap
Mitch
