Old 08-16-2010   #1
new list of parts in my garage
having a moving fire sale on it all. everything I dont want to keep for my self will be taken to the scrap yard for cash in 2 weeks. All good offers taken
1g stuff bins garage
3. awd bearing case 10.00
5. 22 spline out put shaft 15.00
11. fwd starter plate 10.00
14. front lic. plate bracket 10.00
28. power steering pump with pully 20.00
30. 5 speed speedo sensor x2 5.00 each
31. non radiator cap upper t. stat housing 10.00
32. drivers white door handle 5.00
33. drivers greed door handle 5.00
34. pass red door handle x2 5.00 each
2g stuff bins garage
1. lower radiator metal mounts 10.00 set
2. battery tray 10.00
10. knock sensor 25.00
14. upper auto tranny mount alum/rubber x2 20.00 each
21. black review mirror with map lights and wiring 20.00
28. din pocket under raido 5.00 x2 each
37. 7bolt ofh non coolant ofh 10.00
39. awd right rear knuckle 95-96 50.00
53. clutch resavor w/bracket 5.00
4g63 stuff bins garage
1. lower timing tin 10.00
4. power steering heat sheilds x2 10.00 each
5. rear engine lift mounts x2 5.00 each
6. front engine lift mount 5.00
7. alt. arm brackets x6 5.00 each
8. lower fuel pump holder bracket 5.00
16. rear main seal housings x2 10.00 each 7bolt
17. crank balance shaft belt pully x3 10.00 each
18. crank timing belt pully x4 25.00 each
19. oil pump timing belt pully x4 20.00 each
20. crank trigger plates x2 5.00 each
24. oil dip stick tubes x8 5.00 each
mirage/miss stuff bins garage,after market
1. apexi safc mounts ect x2 10.00 each
2. 93-01 mirage raido brackets 10.00 set
3. 89-92 mirage raido brackets 10.00 set
6. evo 1-3 power steering set up no pump 50.00
9. Pte 6776 divided t4 3in vband out. 10an drain fitting,4an feed fitting. 600.00
10. clifford consept 600 alarm 50.00
2g basement shop bins
1. black steering wheel with air bag and cruise non leather mint 40.00
12. lower battery brackt bolts to frame 10.00
33. red gas door 10.00
36. grey map lights w/bracket 10.00
85. key less entry ecu 15.00
87. spyder top control ecu x2 15.00 each
104. new reman upper right control arm front 15.00
105. tan cloth rear spyder seat
Old 09-30-2010   #2
Re: new list of parts in my garage
updated the list
Old 10-15-2010   #3
my2cent
my2cent's Avatar
Drives: 99 gsx
Do u have an alternator for sale for 2g?
my2cent is offline   Reply With Quote
Old 10-15-2010   #4
Sorry I don't just have a few 1g alts
Old 09-22-2012   #5
mitsukid124
mitsukid124's Avatar
Drives: 97 eclipse gst
Would you possibly have the piece that hold the fuel filler door closed? i think i've heard if called the fuel filler door lock actuator, but im not sure.
mitsukid124 is offline   Reply With Quote
Old 09-22-2012   #6
Ya I should have one or two. Other wise I have one in my car the can be taken out since I have a 3G alum gas door
Old 09-22-2012   #7
enasnitsi
Drives: 1993 Talon Awd
Are the 2g pistons stock bore or what are they?
enasnitsi is offline   Reply With Quote
Old 09-22-2012   #8
They were Evo 2 pistons and they are gone
Old 11-06-2012   #9
Updated
Added some parts.
Also added pte6776 and a MHI evo 3 16g
Old 11-27-2012   #10
gsxvince
the dsm mechanic!
Drives: 1991 talon tsi 1ga
do you have the front mount thats on the block for a 1g 5speed the auto one is a different shape, and is smashing into my slave cyl.
Old 11-27-2012   #11
I should have a few of them still
Old 11-27-2012   #12
gsxvince
the dsm mechanic!
how much?
Old 03-20-2013   #13
Old 03-22-2013   #14
mitsukid124
Do you have a 2g gst fuel sending unit?
Old 03-22-2013   #15
99gsxjoel
Drives: 1999 GSX
A
99gsxjoel is offline   Reply With Quote
Old 03-22-2013   #16
Yes
Old 03-22-2013   #17
mitsukid124
pm'd
Old 03-25-2013   #18
scrapped over 1/2 of it today
Old 04-10-2013   #19
CornFed2.4
CornFed2.4's Avatar
Drives: You crazy!
I need the upper auto 2G trans mount. Mine is cracked
Old 04-10-2013   #20
Still have the alum mount still
Also updated a 2nd time scrapped a ton more
