Old 08-21-2010   #1
gohan2058
gohan2058's Avatar
Drives: Stealth TT/Eclipse GS-T
Send a message via MSN to gohan2058 Send a message via Yahoo to gohan2058
Bogging 6bolt PLZ HELP!!!
Ok, my symptoms are as follows:
Driving under steady speed, low acceleration, my car will all of a sudden start bogging down (kinda sounds like a Subaru)
If I let off the gas, the deceleration sounds normal, still sounds weird if i give it more gas.
If I clutch in, let it get to idle n sit there for a second, let the clutch out again, then it goes back to normal.
I've seen other posts kinda similar to this for 6 Bolts and Evos, not really sure what they figured out but last time I checked my plugs they all looked pretty healthy, I know the injectors should be good as they are almost new, and I don't know where else it could be coming from, I can't tell if it's throwing a code cause my 6 bolt swap has always had the CEL on since it's been done with no issues...SAVE ME! If anyone has any advice or at least things to start tearing apart to check on, lemme know
Your responses are much needed and appreciated!
gohan2058 is offline   Reply With Quote
